Lightify led bar
I just bought the lightify led light bar for under cabinent lighting. I tried to add these to smart things but it doesn’t look like they are pairing. Any idea when they might be compatible? In the meantime can I buy the lightify hub and integrate that with smart things?
https://m.lowes.com/pd/SYLVANIA-LIGHTIFY-24-in-Hardwired-Under-Cabinet-LED-Light-Bar/1000128433
I haven’t seen one of these yet. You can probably pair it and change the Device Type in the IDE to either “ZigBee Dimmer” or “ZigBee White Color Temperature Bulb” depending on if it’s just a dimming LED strip or if it allows you to control the color temperature.
