Does anyone know if you could use the lightify bulb and gateway hub with the amazon echo, without using any other hub?
If you mean the lightify Gateway, then yes, since August 2016 this can be used directly with Alexa. However, this method only offers on/off/dim. No color or color temperature adjustment.
