They look lie they should work. Good find!
just curious did you try one of these? I see a slight difference. On the Osram there is one side slightly flat on the connection, this looks completely round so I wanted to check if it had been attempted yet Thanks
First of all, some friendly advice. Donât use power tools if youâve had a few beers. Anyways, I was using my hedge trimmer to cut down the ornamental grasses in my front & cut the 4 wire ribbon cord for my Gardenspot miniâs. Canât find a replacement. Can I just splice the wires together?
Thatâs why I havenât got mine in the garden yet - I donât trust myself not to accidentally mow them!
From what Iâve read, and from what it looks like, once youâre beyond the little Osram box, everythingâs just straight wires.
Stick them in a choc block and youâre laughing. Then when it works, have a to celebrate, then finish the hedge trimmingâŠ
https://m.ebay.com/itm/272241725545?_trksid=p5731.m3795&_mwBanner=1
This item is no longer available. But if you scroll down there are others.
Did the same thing lol.
I can probably hook you up if you havenât found a solution yet. Bought a bunch of kits to string together while ago. Theyâre at another location but Iâll be there next week. Dm me if still stuck.
Do you have any extra power supplies by chance?
Yeah I can probably dig one upâŠSend me your info. Will be least a week until I can get to them.
Thanks, my splice job didnât fix it. Another possibility is that my power source was fried. A contractor plugged in a big compressor & other stuff into the same outlet and blew the GFI outlet it was connected to.
Any chance you could send me both parts? I would pay you what you need.
Think I just figured out how to DM a person. Thought I just had to reply to the email.
