https://us.lightify-api.org/lightify/api/index.html
Has anybody else try coming up with integration with the Lightify Gateway (similar to the integration with the Hue Bridge)?
i think that most people here use the lightify bulbs directly connected to ST or else join the bulbs to their hue hubs. i dont think the lightify adds anything being in the mix as its not particlarly a great platform. but thats probably going to change in the near future with their dimmers that have hit the market etc…
The response from changing light settings on the Lightify app is much much faster.
mine change quickly when using smarttiles or motion to trigger. If you are trying to the ST app, then you are correct… Everything is slower there
this would be helpful as the only way to push software updates to the Lightify devices is using their hub
Right now i have to unpair the device from ST and then Pair with Lightify hub to update and pair again…
