Hello Community, is there a way to set the thermostat (CT 30) when a light switch (GE) is used? We don’t use the basement often but I would like to turn on the heat when one specific light switch is turned on by the kids. It heats up quickly and it would be perfect. Thank you very much for any hints!!! Cheers, Jens
You could try using this:
* Switch Temperature Change
* Copyright 2015 Eric Roberts
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Switch Temperature Change",
namespace: "baldeagle072",
author: "Eric Roberts",
description: "Changes the set temperature after turning on a switch and goes back when switch is turned off",
category: "Green Living",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Preferences") {
input "thermostat", "capability.thermostat", title: "Thermostat", multiple: true, required: true
input "newHeatingSetpoint", "number", title: "Heating Setpoint", required: false
input "newCoolingSetpoint", "number", title: "Cooling Setpoint", required: false
input "switch1", "capability.switch", title: "Switch", required: true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(switch1, "switch.on", "onSwitchHandler")
subscribe(switch1, "switch.off", "offSwitchHandler")
def onSwitchHandler(evt) {
state.originalHeatingSetpoint = thermostat.latestValue("heatingSetpoint")
state.originalCoolingSetpoint = thermostat.latestValue("coolingSetpoint")
if (newHeatingSetpoint) {
thermostat.setHeatingSetpoint(newHeatingSetpoint)
if (newCoolingSetpoint) {
thermostat.setCoolingSetpoint(newCoolingSetpoint)
def offSwitchHandler(evt) {
log.debug("state.originalHeatingSetpoint[0]: ${state.originalHeatingSetpoint[0]}")
thermostat.setHeatingSetpoint(state.originalHeatingSetpoint[0])
thermostat.setCoolingSetpoint(state.originalCoolingSetpoint[0])
Or a simpler one that just goes between heat and off or cool and off (which after I posted, realized that is probably what you wanted):
* Switch To Thermostat
definition(
name: "Switch To Thermostat",
description: "Thermostat is on with switch only",
preferences {
input "heatOrCool", "enum", title: "Heat or Cool?", options: ["Heat", "Cool"]
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
if (heatOrCool == "Heat") {
thermostat.heat()
if (heatOrCool == "Cool") {
thermostat.cool()
thermostat.off()
