My local Best Buy had those on clearance a few weeks ago in the $30 range. I started to jump on it until I read a review that pointed out the infrared stays on all the time, so you have a bulb that is constantly using power (however small). If the infrared is a feature that you want, then sure. But I decided not to use the Plus version in the absence of use for the infrared.
Don’t always believe everything you read in a review. Specs I saw said IR activates when the light is set at 10% or below. As Eric said, you can also set them in the app to only be on during certain times, so the IRs are not on during daylight hours.
