To test, I have made a change driver to another “Zigbee Light Multifunction Mc” driver and I have returned to the same previous driver “Zigbee Light Multifunction Mc-TEST” and the same message (in logs is in bold) has been received and the configuration has been carried out.
2023-08-11T22:42:53.827116529+00:00 TRACE Zigbee Light Multifunction Mc-TEST Setup driver zigbee_light_multifunctions with lifecycle handlers:
DeviceLifecycleDispatcher: zigbee_light_multifunctions
default_handlers:
doConfigure:
infoChanged:
init:
added:
driverSwitched:
removed:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_light_multifunctions → XY Color Bulb
default_handlers:
added:
child_dispatchers:
2023-08-11T22:42:53.828315196+00:00 TRACE Zigbee Light Multifunction Mc-TEST Setup driver zigbee_light_multifunctions with Capability handlers:
CapabilityCommandDispatcher: zigbee_light_multifunctions
default_handlers:
refresh:
refresh
legendabsolute60149.colorChangeTimer:
setColorChangeTimer
colorTemperature:
setColorTemperature
legendabsolute60149.progressiveOff1:
setProgOff
switchLevel:
setLevel
legendabsolute60149.circadian:
setCircadian
legendabsolute60149.colorChanging:
setColorChanging
switch:
on
off
legendabsolute60149.getGroups:
setGetGroups
legendabsolute60149.levelSteps:
setLevelSteps
legendabsolute60149.colorChangeMode1:
setColorChangeMode
legendabsolute60149.mirrorGroupFunction:
setMirrorGroupFunction
colorControl:
setColor
setSaturation
setHue
legendabsolute60149.colorTemperatureSteps:
setColorTempSteps
legendabsolute60149.progressiveOn1:
setProgOn
legendabsolute60149.forcedOnLevel:
setForcedOnLevel
legendabsolute60149.randomOnOff1:
setRandomOnOff
legendabsolute60149.effectsSetCommand:
setEffectsSetCommand
child_dispatchers:
CapabilityCommandDispatcher: zigbee_light_multifunctions → XY Color Bulb
default_handlers:
colorControl:
setColor
setSaturation
setHue
child_dispatchers:
2023-08-11T22:42:53.830143529+00:00 TRACE Zigbee Light Multifunction Mc-TEST Setup driver zigbee_light_multifunctions with Zigbee handlers:
ZigbeeMessageDispatcher: zigbee_light_multifunctions
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: CurrentSaturation
ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: CurrentHue
ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: ColorTemperatureMireds
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_light_multifunctions → XY Color Bulb
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: CurrentY
ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: CurrentX
global:
cluster:
zdo:
child_dispatchers:
2023-08-11T22:42:53.897654529+00:00 TRACE Zigbee Light Multifunction Mc-TEST Zigbee Device: 84944c69-fa8e-417e-bb62-92b7d5087d63
Manufacturer: OSRAM Model: Classic A60 W clear - LIGHTIFY
[3]: server: TouchlinkCommissioning, Basic, Identify, Groups, Scenes, OnOff, Level, 0xFC0F | client: OTAUpgrade
2023-08-11T22:42:53.898812529+00:00 DEBUG Zigbee Light Multifunction Mc-TEST driver device thread event handled
2023-08-11T22:42:53.900169862+00:00 TRACE Zigbee Light Multifunction Mc-TEST Received event with handler _resync
2023-08-11T22:42:53.901445529+00:00 TRACE Zigbee Light Multifunction Mc-TEST Received event with handler environment_info
2023-08-11T22:42:53.902727529+00:00 DEBUG Zigbee Light Multifunction Mc-TEST Z-Wave hub node ID environment changed.
2023-08-11T22:42:53.917327196+00:00 TRACE Zigbee Light Multifunction Mc-TEST Found DeviceLifecycleDispatcher handler in zigbee_light_multifunctions
2023-08-11T22:42:53.926454529+00:00 PRINT Zigbee Light Multifunction Mc-TEST <<<<< Device Init >>>>>>
2023-08-11T22:42:53.928005862+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> emitting event: {“state”:{“value”:“Inactive”},“component_id”:“main”,“capability_id”:“legendabsolute60149.progressiveOn1”,“attribute_id”:“progOn”}
2023-08-11T22:42:53.938999862+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> emitting event: {“state”:{“value”:“Inactive”},“component_id”:“main”,“capability_id”:“legendabsolute60149.progressiveOff1”,“attribute_id”:“progOff”}
2023-08-11T22:42:53.959217529+00:00 WARN Zigbee Light Multifunction Mc-TEST Attempted to generate event for 84944c69-fa8e-417e-bb62-92b7d5087d63.main but it does not support capability
Circadian
2023-08-11T22:42:53.963058529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> emitting event: {“state”:{“value”:“Inactive”},“component_id”:“main”,“capability_id”:“legendabsolute60149.randomOnOff1”,“attribute_id”:“randomOnOff”}
2023-08-11T22:42:53.988303196+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> emitting event: {“state”:{“value”:“Inactive”},“component_id”:“main”,“capability_id”:“legendabsolute60149.randomNextStep”,“attribute_id”:“randomNext”}
2023-08-11T22:42:54.052575196+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> emitting event: {“state”:{“value”:0},“component_id”:“main”,“capability_id”:“legendabsolute60149.forcedOnLevel”,“attribute_id”:“forcedOnLevel”}
2023-08-11T22:42:54.059180196+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> emitting event: {“state”:{“value”:“Inactive”},“component_id”:“main”,“capability_id”:“legendabsolute60149.mirrorGroupFunction”,“attribute_id”:“mirrorGroupFunction”}
2023-08-11T22:42:54.078539196+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> emitting event: {“state”:{“value”:“Inactive”},“component_id”:“main”,“capability_id”:“legendabsolute60149.effectsSetCommand”,“attribute_id”:“effectsSetCommand”}
2023-08-11T22:42:54.094090862+00:00 DEBUG Zigbee Light Multifunction Mc-TEST Luz Mesita device thread event handled
2023-08-11T22:42:54.100350196+00:00 TRACE Zigbee Light Multifunction Mc-TEST Received event with handler environment_info
2023-08-11T22:42:54.106653862+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> generating doConfigure event for nil provisioning state
2023-08-11T22:42:54.186809862+00:00 TRACE Zigbee Light Multifunction Mc-TEST Found DeviceLifecycleDispatcher handler in zigbee_light_multifunctions
2023-08-11T22:42:54.187885529+00:00 TRACE Zigbee Light Multifunction Mc-TEST Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2023-08-11T22:42:54.189272529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2023-08-11T22:42:54.218250196+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2023-08-11T22:42:54.366230862+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 7CB03EAA0A04B6BE, src_endpoint: 0x03, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000204B680, dest_endpoint: 0x01 > >
2023-08-11T22:42:54.416598196+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2023-08-11T22:42:54.437599862+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 7CB03EAA0A04B6BE, src_endpoint: 0x03, cluster: Level, dest_addr_mode: 0x03, dest_address: 286D97000204B680, dest_endpoint: 0x01 > >
2023-08-11T22:42:54.479584529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint8, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 0x01 > > > >
2023-08-11T22:42:54.541318529+00:00 DEBUG Zigbee Light Multifunction Mc-TEST Luz Mesita device thread event handled
2023-08-11T22:42:54.542625196+00:00 DEBUG Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> doConfigure callback did not fail, transitioning device to “PROVISIONED”
2023-08-11T22:42:54.548939529+00:00 TRACE Zigbee Light Multifunction Mc-TEST Received event with handler device_lifecycle
2023-08-11T22:42:54.550256196+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> received lifecycle event: added
2023-08-11T22:42:54.599543862+00:00 DEBUG Zigbee Light Multifunction Mc-TEST Luz Mesita device thread event handled
2023-08-11T22:42:54.600487196+00:00 TRACE Zigbee Light Multifunction Mc-TEST Received event with handler device_lifecycle
2023-08-11T22:42:54.601731529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> received lifecycle event: driverSwitched
2023-08-11T22:42:54.629267529+00:00 TRACE Zigbee Light Multifunction Mc-TEST Found DeviceLifecycleDispatcher handler in zigbee_light_multifunctions
2023-08-11T22:42:54.630505529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2023-08-11T22:42:54.897294529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4003, DataType: Enum8, data: 0xFF > > > >
2023-08-11T22:42:54.979922529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x8002, DataType: Enum8, data: 0x02 > > > >
2023-08-11T22:42:55.266335529+00:00 PRINT Zigbee Light Multifunction Mc-TEST Remove Groups >>>>>>>>>>>>>>>>>
2023-08-11T22:42:55.273285529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x04 >, < RemoveAllGroups || > > >
2023-08-11T22:42:55.462572529+00:00 INFO Zigbee Light Multifunction Mc-TEST <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC0CD, dest_endpoint: 0x03, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2023-08-11T22:42:55.721902196+00:00 PRINT Zigbee Light Multifunction Mc-TEST Device ID <ZigbeeDevice: 84944c69-fa8e-417e-bb62-92b7d5087d63 [0xC0CD] (Luz Mesita)>
2023-08-11T22:42:55.736245196+00:00 PRINT Zigbee Light Multifunction Mc-TEST Manufacturer >>> OSRAM Manufacturer_Len >>> 5
2023-08-11T22:42:55.737570196+00:00 PRINT Zigbee Light Multifunction Mc-TEST Model >>> Classic A60 W clear - LIGHTIFY Model_len >>> 30
2023-08-11T22:42:55.740076529+00:00 PRINT Zigbee Light Multifunction Mc-TEST <<<<< Firmware Version >>>>> 01020412
2023-08-11T22:42:55.741351529+00:00 PRINT Zigbee Light Multifunction Mc-TEST Memory >>>>>>> 962.966796875 Kbytes
