Lidl Smart Home with SmartThings
Forget about these old DTHs, they won’t work after Groovy is phased out. Edge drivers are the future. Check out drivers made by @Mariano_Colmenarejo. If I remember correctly there is a driver for this device.
If you don’t know anything about Edge drivers then I’d recommend checking this out.
Hi Luis, I’ve been breaking my head over this SilverCrest gardenpin outlet that I’ve gotten from Lidl. It has two outlets but I can’t seem to get this thing to work. It recognized the unit as a thing and when I change the DTH into your integrated_zigbee_Switch. It seems to accept it as a switched outlet but it only works on the whole unit not the individual two outlets separately. It does show them as child devices though! Any tips you can give me? BTW the * manufacturer: _TZ3000_br3laukf
  • model: TS0101 for reference. Thanks Erwin
Thanks @Sakari !
I am also looking in the direction of the edge driver and messaged Mariano for help.
However, in the meantime, I am concerned that the groovy script is not at all working as intended… Perhaps I have a version of the device that isn’t supported?
Here is what smartthings tells me when the plug is installed as “outlet” (default Zigbee groovy device)
application: 46
endpointId: 01
manufacturer: _TZ3000_vzopcetz
model: TS011F
zigbeeNodeType: ROUTER
I’m sure Mariano can help you. I unfortunately don’t understand enough about these devices and especially about old dths.
Thanks @Sakari
I am having troubles with the Silvercrest (Lidl) Smart Button. I’ve tried the device handler: Zigbee Non-Holdable Button, but so far no luck. Please Help!
Data:
  • application: 47
  • endpointId: 01
  • manufacturer: _TZ3000_rco1yzb1
  • model: TS004F
  • zigbeeNodeType: SLEEPY_END_DEVICE
Did you figure this out yet? Because I cant for the life of me not get this thing to work either. Not even a single press. @lucien
