Does SmartThings have the concept of a level sensor with an appropriate tile render in the system?
I need to monitor the levels of my water tanks and I see there are ultrasonic sensors available. Before I even start looking for a SmartThings compatible option I thought I’d ask if the platform even supports this type of device.
The intention would be to cut power to my pump if the level gets too low.
I currently am using an ultrasonic zigbee sensor for my automatic fertilizer system. It works fine. My only issue is that it only shows measurement in meters and im using a 5gal bucket lol. Nonetheless i have it working just fine. Its set up to when the level is at 68%, that will alert me that its low.
It would definitely work with water, i tested my system with water before filling with fertilizer… id imagine solids would be fine too… but never tried solids.
Tuya WiFi/Zigbee Smart Ultrasonic Liquid Level Sensor APP Remote Real-time Monitor Water Oil Storage Tank Depth Detection Alarm
Obviously just make sure you select the zigbee US version. But ya, this is the one im currently using. Been using it for around 3 months now and its been fine.
