Level Control Move Command
Hi,
I wanted to know how I could implement the move command of the Switch Level capability which according to Sticks18 is “Move - this command simply tells the light to get brighter (Up direction 00) or dimmer (Down direction 01) and the rate you want it to transition (00-fe) in units per second.” My goal is to have the usual on and off command to turn on/off a dimmer immediately, but I always want to have 2 other standardTiles with one to MOVE it brighter and the other to MOVE it dimmer. I would really appreciate any help to achieve this task. Thanks.
