Leds glowing at around 5% when off
Had a battle with the Fibaro dimmer 2 couldnt get any joy using it with the ST found device which I believe is a generic Z Wave dimmer so I changed it for the Hajar97 Hajar97 device and amazingly it started working (I’m new to this), unfortunately with it off I still get a glow of around 5%. The led’s are supposedly 7w and theres a dozen of them so I cant see the problem is in too low power. Any assistance very much appreciated.
Hi David,
I had the same thing happen to me and it ended up being the programmable switch I was using. Changed it out to a GE Smart Switch and the problem went away
Good luck with your quest
Rick
Hi Davidj,
I have a couple of Cree Connected bulbs bahaving the same way. I have not been able to remedy this situation.
The switch is not a connected switch, just a simple single pull switch.
Darth
Hey,
Mine wasn’t a connected switch either. It had a sunset/sunrise timer built in but that’s it, no dimmer, not smart… Once I changed it out, the bulbs stopped glowing when off.
Good luck
Rick
I’ve taken the switch out of the circuit. I still get same so it’s not the switch, which is a very basic on off one anyway.
