UPDATE 7/9/2019: I put all my code on Github, as formatting here is messed up:
I regularly get requests for the latest version of this app: “Smart Light Timer, X minutes unless already on”, so I thought I’d post it to make it easier to find.
This app will listen for a variety of of triggers. When triggered, it will turn on a set of switches (or other actions), for a configurable amount of time. If more actions happens WHILE the lights are on, the timer will be extended. If switches are toggled off/on while the lights are in timer mode, the timer will STOP and the lights remain on. If the lights are already ON when the trigger happens, NO timer is started, and the lights simply stays on.
I use this extensively throughout my home, and it solves a bunch of problems that Smartthings could not be bothered solving in their standard app.
Hope this makes it easier to find. This version has been pending publication in Smartthings for 3 years, and is the newest version.
Cheers
Anders
- Smart Timer
- Loosely based on “Light Follows Me”
- This prevent them from turning off when the timer expires, if they were already turned on
- If the switch is already on, if won’t be affected by the timer (Must be turned of manually)
- If the switch is toggled while in timeout-mode, it will remain on and ignore the timer (Must be turned of manually)
- The timeout perid begins when the contact is closed, or motion stops, so leaving a door open won’t start the timer until it’s closed.
- Author: andersheie@gmail.com
- Date: 2015-10-30
*/definition(
name: “Smart Light Timer, X minutes unless already on”,
namespace: “Pope”,
author: “listpope@cox.net”,
description: “Turns on a switch for X minutes, then turns it off. Unless, the switch is already on, in which case it stays on. If the switch is toggled while the timer is running, the timer is canceled.”,
category: “Convenience”,
iconUrl: “http://upload.wikimedia.org/wikipedia/commons/6/6a/Light_bulb_icon_tips.svg”,
iconX2Url: “http://upload.wikimedia.org/wikipedia/commons/6/6a/Light_bulb_icon_tips.svg”)preferences {
section(“Turn on when there is movement…”){
input “motions”, “capability.motionSensor”, multiple: true, title: “Select motion detectors”, required: false
section(“Or, turn on when one of these contacts opened”){
input “contacts”, “capability.contactSensor”, multiple: true, title: “Select Contacts”, required: false
section(“Or, turn on when any of these people come home”) {
input “peoplearrive”, “capability.presenceSensor”, multiple: true, required: false
section(“Or, turn on when any of these people leave”) {
input “peopleleave”, “capability.presenceSensor”, multiple: true, required: false
section(“And off after no more triggers after…”){
input “minutes1”, “number”, title: “Minutes?”, defaultValue: “5”
section(“Turn on/off light(s)…”){
input “switches”, “capability.switch”, multiple: true, title: “Select Lights”
}def installed()
log.debug “installed()”
initialize()
}def updated()
log.debug “updated()”
initialize()
}def initialize()
log.debug “initialize()”
// Reset to new set of Switches, just in case.
unsubscribe()state.switches = [:] switches.each { // log.debug "ID: $it.id" // Set ready state for each switch state.switches["$it.id"] = "ready" } logStates()
subscribe(motions, “motion”, motionHandler)
subscribe(switches, “switch”, switchChange)
subscribe(contacts, “contact”, contactHandler)
subscribe(peoplearrive, “presence.present”, presencePresentHandler)
subscribe(peopleleave, “presence.not present”, presenceNotPresentHandler)
state.lastAction = null
schedule(“0 * * * * ?”, “scheduleCheck”)}
def logStates() {
if(state.switches == null) {
state.switches.each {
log.debug “State: $it.key = $it.value”
}def turnSwitchOn(id) {
for(S in switches) {
if(S.id == id) {
S.on()
}def turnSwitchOff(id) {
if(S.id == id) {
S.off()
}def initState(deviceID) {
// Have to add this so existing apps that are neither updated nor initiated can slowly get ‘reset’ with states.
// Smartthings doesn’t call any specific method when new version is published.if(state.switches == null) {
if(state.switches[deviceID] == null) {
state.switches[deviceID] = “ready”
def switchChange(evt) {
def deviceID = evt.device.id
log.debug "SwitchChange: $evt.name: $evt.value $evt.device.id current state = " + state.switches[deviceID]
initState(deviceID)if(evt.value == “on”) {
if(state.switches[deviceID] == “activating”) {
// OK, probably an event from Activating something, and not the switch itself. Go to Active mode.
log.debug “$deviceID = " + state.switches[deviceID] + " → active”
state.switches[deviceID] = “active”
} else if(state.switches[deviceID] != “active”) {
log.debug “$deviceID = " + state.switches[deviceID] + " → already on”
state.switches[deviceID] = “already on”
} else {
// If active and switch is turned of manually, then stop the schedule and go to ready state
logStates()}
def contactHandler(evt) {
log.debug “contactHandler: $evt.name: $evt.value”state.switches.each { thisswitch -> initState(thisswitch.key) //log.debug "Looking for $thisswitch.key" if (evt.value == "open") { if(state.switches[thisswitch.key] == "ready") { log.debug "Turning on lights by contact opening: $thisswitch" log.debug "$thisswitch.key = " + state.switches[thisswitch.key] + " -> activating" state.switches[thisswitch.key] = "activating" turnSwitchOn(thisswitch.key) setActiveAndSchedule() } } else if (evt.value == "closed") { if (!state.lastAction && (state.switches[thisswitch.key] == "active" || state.switches[thisswitch.key] == "activating")) { // When contact closes, we reset the timer if not already set log.debug "$thisswitch.key = " + state.switches[thisswitch.key] + " -> active" state.switches[thisswitch.key] = "active" setActiveAndSchedule() } } } logStates()
def scheduleCheck() {
log.debug “schedule check, ts = ${state.lastAction}”
boolean resetInactive = false
state.switches.each { thisswitch →
if(state.switches[thisswitch.key] != “already on”) {
if(state.lastAction != null) {
def elapsed = now() - state.lastAction
log.debug “${elapsed / 1000} sec since events stopped”
def threshold = 1000 * 60 * minutes1
if (elapsed >= threshold) {
if (state.switches[thisswitch.key] == “active”
|| state.switches[thisswitch.key] == “activating”) {
state.switches[thisswitch.key] = “ready”
log.debug “Turning off lights by switch closing: $thisswitch”
turnSwitchOff(thisswitch.key)
resetInactive = true
if(resetInactive) {
unschedule()
logStates()
def motionHandler(evt) {
log.debug "motionHandler: $evt.name: $evt.value (current state: " + state.myState + “)”state.switches.each { thisswitch →
if (evt.value == “active”) {
if(state.switches[thisswitch.key] == “ready”
|| state.switches[thisswitch.key] == “activating” ) {
log.debug “$thisswitch.key = " + state.switches[thisswitch.key] + " → activating”
state.switches[thisswitch.key] = “activating”
} else if (evt.value == “inactive”) {
if (state.switches[thisswitch.key] == “active” || state.switches[thisswitch.key] == “activating”) {
// When Motion ends, we reset the timer if not already set
log.debug “$thisswitch.key = " + state.switches[thisswitch.key] + " → active”
state.switches[thisswitch.key] = “active”
logStates()
}def presencePresentHandler(evt) {
log.debug “presence: $evt.linkText is now $evt.value”state.switches.each { thisswitch -> initState(thisswitch.key) if (evt.value == "present") { if(state.switches[thisswitch.key] == "ready" || state.switches[thisswitch.key] == "active" || state.switches[thisswitch.key] == "activating" ) { log.debug "Presence turning on switch $thisswitch" state.switches[thisswitch.key] = "active" turnSwitchOn(thisswitch.key) // We don't wait until the person leave, but instead start timer immediately. setActiveAndSchedule() } } } logStates()
def presenceNotPresentHandler(evt) {
log.debug “presence: $evt.linkText is now $evt.value”state.switches.each { thisswitch -> initState(thisswitch.key) if (evt.value == "not present") { if(state.switches[thisswitch.key] == "ready" || state.switches[thisswitch.key] == "active" || state.switches[thisswitch.key] == "activating" ) { log.debug "No Presence turning on lights $thisswitch" state.switches[thisswitch.key] = "active" turnSwitchOn(thisswitch.key) // We don't wait until the person arrive back, but instead start timer immediately. setActiveAndSchedule() } } } logStates()
def setActiveAndSchedule() {
unschedule()
state.lastAction = now()
log.debug “Scheduled new timer”
