We are excited to announce the first group of community-created device integrations are now released to SmartThings Labs for anyone to check out. This Quirky Pivot Power Genius integration was created by none other than Todd Wackford (@twack).
Product Info
Pivot Power Genius is an app-enabled version of the Quirky power strip. Like the original, it bends to fit every sized plug or adapter without wasting a single outlet. This one puts the power at your fingertips, allowing you to independently control two outlets from your mobile device. Use the Quirky (Connect) SmartApp to easily connect this product to your SmartThings system.
You can get an additional 20% off the Pivot Power Genius on thinkgeek bringing the total to only $15.99 for the next 16 hours using think promo code FIFTHOFF
I have two of these strips, got them set up and added to SmartThings no problem. I did run into an issue though:
Yesterday I cut the power to my home network. The power strips reconnected and receive commands just fine, however, they no longer report their status to SmartThings. When tapping ‘refresh’ within the mobile app SmartThings updates the state of the switch. I tried just refreshing the installed connect app but that didn’t help.
Great to hear @twack. Also, incredible job on this and the TCP integration! Made a huge difference in my setup and capabilities, especially on a budget. I appreciate the hard work more than I could ever show.
@twack - absolutely love the ability to control the Pivot Power Genius from SmartThings (bought 5 from ThinkGeek during their sale), thanks for all your contributions to the ST community! Running into one strange issue with them though and was wondering if you have come across a similar issue. Something seems to be sending off commands to the powerstrip. I am not seeing anything in the ST logs showing that an off command is being pushed to the switches, and I do not have any triggers setup in the Wink app.
Below is what is shown in the logs for a specific switch. Somewhere in between the two time stamps is where the off command was initiated.
Have you ran across any instances of the Pivot Power Genius switches randomly turning off?
Is it happening to all of the strips, or just one? Does it happen if there is a load or not? Meanwhile I’ve reached out to Quirky to see if they have seen anything like this.
I’m thinking this has nothing to do with what you are seeing @nelemansc, but I noticed if the power strips lose their wifi connection they switch the two outlets off. Not my preferred behavior, though that would be on the Quirky side of things.
That sounds like it could be my root cause. Both outlets do switch off simultaneously. I’ll test tonight with the additional strip closer to the router to see if it is a signal strength issue.
Out of eight I have three strips hooked (2nd day using them) and so far they’ve been working fine. I’m not home to verify but I see them behaving based on app preference. I accidentally ordered 8 instead of 4 which I was going to return but now I’m thinking about keeping them all. Hope Wink is reliable with many devices.
One small update : quirky outlets don’t seem to report status correctly. Whether I manually turn an outlet on dashboard or let an app do it it always says it’s off. (So I had to click twice to manually turn them off.) In case of manual switch on the icon does change to on status but goes back to off when I go out of st app and go back to it.
I hooked up two additional powerstrips last night, strip #1 at ~2 feet from the router, strip #2 at ~20 feet from the router, and then the original strip (#3) hooked up in the bedroom at ~40 feet away through wood/concrete. Strips 1 & 2 were both still on this morning, while strip #3 was off. It looks like @ronnycarr 's findings match up with mine. Thanks for your input, Ronny. It would’ve taken me a bit to discover that as being the issue.
This is a known issue. There is a fix submitted, but not released into the labs version yet. ST folks will hopefully let it go this week or next. Thanks for the observation/report though.
I have forwarded you info to the Quirky peoples. I’ll let you know what they say as soon as I get word back.
Everyone,
What would expect the strip to do if it looses WiFi connection? THink of safety issues too. Realize that it would not be able to be shut off. But then again, a normal power strip can’t be turned off remotely at all? ANyway, let me know your thoughts.
Thanks @twack. I’ll wait for the update. (Does it happen in the background or via ST app update?)
As for wifi signal loss, I think ideal way is to have them stay the same status by default with an option for off. You wouldn’t want your reading lamp turned off just because of wifi problem, but you would rather have an electric heater off when you are away and don’t know how hot it is getting. But then this is only possible with some firmware update by Quirky, I assume. On ST side, is it possible to have a report on quirky’s wifi status?
