Trying to get a my Kwikset 910 paired with the hub…got it sitting RIGHT NEXT to it…tryed clearing it (press program three times with the battery pack out), but cannot get it to pair. Any suggestions?
I just press the B button to pair mine. I did mount mine on the door first and held down the lock button while I installed the battery. Then I took it off and moved close to the hub. Also my directions didn’t say anything amount pressing the button 3 times to unpair. Just said use the B button. Mine did not have correct lock status til I realized it was not extending far enough into the door jamb. I just drilled athe hole deeper
When you press the ‘B’ button does the red light come on. If not I would reseat the HomeConnct module.
