# Kwikset 910 Lock Not Showing Correct Lock Status in ST App or Alexa
**URL:** <https://community.smartthings.com/t/kwikset-910-lock-not-showing-correct-lock-status-in-st-app-or-alexa/236344>\
**Category:** Devices & Integrations\
**Created:** [December 18, 2021, 2:17pm UTC](https://community.smartthings.com/t/kwikset-910-lock-not-showing-correct-lock-status-in-st-app-or-alexa/236344 "2021-12-18T14:17:36Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![RBoy](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/rboy/32/62677_2.png) [@RBoy](https://community.smartthings.com/u/RBoy)\
**Post date:** [December 21, 2021, 3:44pm UTC](https://community.smartthings.com/t/kwikset-910-lock-not-showing-correct-lock-status-in-st-app-or-alexa/236344/2 "2021-12-21T15:44:53Z")
</div>
Try to exclude and pair your lock again, sometimes it loses directional communication (i.e. updates only flow in one direction). Also try adding a buffering device near your lock and it may help reduce communication issues:
> [@FAQ: why would I need another beaming repeater if my zwave lock is already close to my hub?](https://community.smartthings.com/t/faq-why-would-i-need-another-beaming-repeater-if-my-zwave-lock-is-already-close-to-my-hub/137629/2):
> Absolutely right JD. This question is the number 1 question we get from users in many different forms. I’ll outline the [most common symptoms](https://community.smartthings.com/t/release-rental-lock-automater-automate-user-guest-codes-schedules-and-actions-with-airbnb-homeaway-vrbo-tripadvisor-and-booking-com-for-multiple-properties/124785/17) folks experience when using locks: My lock is 5ft from my [hub](https://amzn.to/3RK8oTA) I can see the lock/unlock events in the history but I don’t see the user code/name I can lock/unlock using my mobile app but my codes aren’t being programmed [Some of my codes are being programmed while others aren’t](https://community.smartthings.com/t/release-lock-user-management-door-lock-code-manager-create-delete-and-schedule-codes-with-automatic-lock-unlock-custom-user-actions-and-shm-adt-integration-lum/7043/1358)[My codes are being programmed](https://community.smartthings.com/t/release-lock-user-management-lum/7043) but I’m not getting notifications/actions aren’t being executed when the codes are used It works in the mornings but not in the evenings It was working till recently and now it’s having trouble I moved my lock closer/next to my hub but I’m still having issues One of my locks is working perfectly, the other one ([closer to the hub](https://community.smartthings.com/t/offline-online-z-wave-schalge-lock-2-meters-from-hub/189940/6)) is having tr…
_[View the full topic](https://community.smartthings.com/t/kwikset-910-lock-not-showing-correct-lock-status-in-st-app-or-alexa/236344)._
