Yes I assume so. It basically never switches off the power and trickles a tiny amount through. Hence if you have insufficient load you need an extra module in the circuit to prevent sensitive led lights from flickering. This however does not mention being a dimmer.
This also looks to be an absolute bargain at the price it is being sold at in China. Half the price of the Fibaro module for a complete 3 gang switch.
LOL Most countries outside the US use 240v. Remember itās current that kill not voltage. Also most homes are equipped with RCDs here and electrical wiring standards are pretty strict.
I am looking back at this thread. I PMāed teohwk before about the Schneider Electric Ulti range.
They work perfectly and simply.
I am in Hong Kong and you can get these fairly easily. I walked into an electrician 2 days ago and walked out with 2 one-gang switches. Took me 5 minutes and install them and another 5 to set them up on ST. Zigbee and no neutral required.
I was fiddling around with the Fibaro Dimmer 2 and still havenāt gotten it to work.
However these are not cheap - even in Hong Kong. About 120 GBPs equivalent (at the current exchange rate) each.
Partial success, but the sheer size of it was a problem for me. I really want to have some more powered zigbee deivces in the house but weāre very limited for choice here in the UK. In the end I had to compromise and buy a bunch of fibaro zwave inserts as I couldnāt keep on waiting. Not ideal as I would have loved to have purchased more kudleds.
The first company to make an attractive light switch with the same technology built in as the fibaro dimmers, in a simple swap out replacement for 1/2/3/4 gang light switches will clean up in the UK, especially if they can cope with the two wire system like the fibaro dimmers.
The modules are fine, but with even 40mm back boxes, if itās a 2 gang or more light switch, the bolster will need to come out on solid walls or the back sawn out of board wall boxes.
If it were a simple plug and play light switch available in a range of finishes they would own the UK market imho
