Kevo Plus Device Type (DTH Link in post 18)
Were you able to unlock the door via voice? That is what is blocked via Google Assistant for me.
Yep, it works for me. Are you saying “Activate [routine name]”?
Yep. See how I set up my routine and what it says when I say “Activate Unlock Front Door”.
The name doesn’t line up between the screenshots, because I tried updating the name to see if that fixed it. Nope.
What am I missing?
I’ve named my routine “Unlock Side Door”, then I said to Google Assistant: “Sync My Devices”, then to trigger the routine, I say “Activate Unlock Side Door”. As far as I understand it, the “Activate” keyword is a special word for Google Assistant to serve as the prefix to execute any established routine. I hope that helps, cause that’s all I got.
Thanks for the tips. Mine still only can lock, not unlock :frowning:
Not sure why “Assistant is not permitted to do so” on my phone but not yours.
I need some help here. I’m brand new to the smartthings community and i’m having no luck getting this working. I have setup the device handler and the smartapp from the github repository. I setup the new device using the “Kevo Unofficial” item type, and edited the device with my Kevo user name, password, and copied the Kevo LockID from the website.
I’m assuming I did something wrong, because I am not able to get the lock to do anything. When I open the Samsung Connect app and try to click on the device all i get is “Cannot Connect to device”. Not sure how to check it any other way or where to access the logs for this device. Any help would be appreciated.
Okay so disregard. I got it to work in the smart things app, but I am now getting the same error that Eric is getting. I can lock my doors but not unlock them.
Unlocking seems to have a delay of a few seconds longer than locking does. No idea why.
Also, THANK YOU!!!
I’ve been trying to get at least the ability to lock the doors at night, and this has worked nearly flawlessly.
i imported the DH, and added the device, but smartthings is constantly reporting it as ‘jammed’ and none of the operations work thru it. reports and operates properly thru the kevo app, and alexa
I seem to be having the same issue you had. I’ve setup the device handler, smartapp, and setup the locks as new devices with my Kevo username, password, and lockID. The Samsung website is able to get updates from mykevo in regards to the status of my locks. However, the Smartthings/Samsung Connect app says “Cannot connect to device.” How were you able to fix this in the app?
I’ve been using this for months now with almost zero problems, but over the last 24 hours or so, the lock has started showing as “jammed” in Smartthings, but fine in the Kevo app. I have the door lock and unlock based on the presence of my wife and I coming or leaving and she’s started shouting at me because the front door doesn’t automatically unlock when she gets home… help and help quickly!! :slight_smile:
Here’s what I’m seeing in the logs…
Hey folks, I’ll take a peek at these hopefully later this week or over the weekend. There might have been a recent change in the KEVO api that’s causing the jammed message (personally I get the “device unavailable” until I force a lock/unlock/refresh sometimes rather than the jammed message.)
In the meantime, here’s what the HTTP codes usually mean:
500 - server error
200 - Successful request
302 - redirect to another url - this is usually due to an auth issue
Lastly, I HIGHLY HIGHLY HIGHLY recommend against unlocking via voice. All it takes is some a-hole outside your house screaming “ACTIVATE UNLOCK DOORS” or some such and getting right in. This is why Google and Alexa generally prevent using unlock capabilities via voice - its a huge security hole.
If there’s other issues, please make sure to file an issue in github. It makes it much easier to track.
I have updated code in the development branch of the github repo. Setup a second device using that branch instead and then in the device preferences check “enable debug logging”. That should produce significantly more logging data. See if that gives some insight.
Thanks! Sorry, I’ll report issues in github next time. I modified the code locally to update status after 5 seconds, rather than 2, but I’m not sure that “fixed” the issue.
The problem has gone away but I’m not sure it’s because I changed the code, I think there must have been an issue at the Kevo end as you state above. The 500’s gave me that impression.
I’m going to change my code back to your standard code, but I appreciate you looking into it. I’m assuming that you also had the same issue if you saw similar messages?
You can avoid the security issues by using a secret phrase for unlocking. I have mine set through IFTTT when I say a phrase that only my wife and I know, to trigger Kevo to unlock. We do not tie kevo directly to google, thus, unlocking by voice can only be done by using the secret phrase. (To be clear, we unchecked Kevo as one of the devices available to google assistant in the smart app in Smartthings)
So, first you make sure Smartthings and Google Assistant are linked to IFTTT, and your Kevo is setup using the Kevo Device type . Second, you create an applet with Google Assistant with “Say a simple phrase” as the trigger in the “if this” section. Then, you create the triggers to be the secret phrase you will remember. Then, you set the action in the “+That” section to unlock your Kevo Lock (Through the Smartthings service, select your kevo, and select unlock as the action)
You can also do the same thing locking Kevo.
I went here and tried to create the device handler. Everything works exactly as you’ve stated; however, when I scroll to the bottom of the device type list, there’s no ‘Kevo Unofficial’. I scrolled the entirety of the list 3 times and can’t find it. Is it perhaps labeled as something less obvious now?
Nevermind, I figured it out. Might help if I add the device handler first. I’m new here :crazy_face:
Seems to have stopped working. Anyone else having issues?
{GUID} 5:35:53 PM: error couldn’t determine lock status after refreshing, null
{GUID} 5:35:53 PM: warn Couldn’t update state from java.lang.IllegalArgumentException: Failed to complete. Message was: General SSLEngine problem
{GUID} 5:35:53 PM: trace not logged in, redirecting to login start
{GUID} 5:35:53 PM: trace refresh:0
{GUID} 5:35:31 PM: warn Couldn’t update state from java.lang.IllegalArgumentException: Failed to complete. Message was: General SSLEngine problem
{GUID} 5:35:31 PM: trace not logged in, redirecting to login start
{GUID} 5:35:31 PM: trace unlock
I’m having the same problem. I think there might have been a firmware update.
© 2019 SmartThings, Inc. All Rights Reserved. Terms of Use | Privacy Policy
SmartThings; SmartApps®; Physical Graph; Hello, Home; and Hello, Smart Home are all trademarks of the SmartThings, Inc.
