Can someone help me with the code for Keep Me Cozy? I want to be able to only let the program run if a switch is on. ie: “Thermostat Override” -A virtual switch I created. I want to get rid of the mode feature and replace it with the ability to app a switch to enable/disable.
when it is extremely hot out “keep me cozy II” works great since the thermostat is on the 1st floor and I use the sensor on the 2nd floor. when the temperatures are a little nice I want to use the normal thermostat. I find myself constantly deleting and adding Keep Me Cozy II. when in reality I just want to disable it with a simple switch. Here is the code. or GitHub Mcodding / CoddingSmartApps (KeepMeCozyInterlock)
preferences() {
section("Choose thermostat...") {
input "thermostat", "capability.thermostat"
section("Heat setting..." ) {
input "heatingSetpoint", "decimal", title: "Degrees"
section("Air conditioning setting...") {
input "coolingSetpoint", "decimal", title: "Degrees"
section("Optionally choose temperature sensor to use instead of the thermostat's...") {
input "sensor", "capability.temperatureMeasurement", title: "Temp Sensors", required: false
def installed()
log.debug "enter installed, state: $state"
subscribeToEvents()
def updated()
log.debug "enter updated, state: $state"
unsubscribe()
subscribeToEvents()
def subscribeToEvents()
subscribe(location, changedLocationMode)
if (sensor) {
subscribe(sensor, "temperature", temperatureHandler)
subscribe(thermostat, "temperature", temperatureHandler)
subscribe(thermostat, "thermostatMode", temperatureHandler)
evaluate()
def changedLocationMode(evt)
log.debug "changedLocationMode mode: $evt.value, heat: $heat, cool: $cool"
evaluate()
def temperatureHandler(evt)
evaluate()
private evaluate()
if (sensor) {
def threshold = 1.0
def tm = thermostat.currentThermostatMode
def ct = thermostat.currentTemperature
def currentTemp = sensor.currentTemperature
log.trace("evaluate:, mode: $tm -- temp: $ct, heat: $thermostat.currentHeatingSetpoint, cool: $thermostat.currentCoolingSetpoint -- " +
"sensor: $currentTemp, heat: $heatingSetpoint, cool: $coolingSetpoint")
if (tm in ["cool","auto"]) {
// air conditioner
if (currentTemp - coolingSetpoint >= threshold) {
thermostat.setCoolingSetpoint(ct - 2)
log.debug "thermostat.setCoolingSetpoint(${ct - 2}), ON"
else if (coolingSetpoint - currentTemp >= threshold && ct - thermostat.currentCoolingSetpoint >= threshold) {
thermostat.setCoolingSetpoint(ct + 2)
log.debug "thermostat.setCoolingSetpoint(${ct + 2}), OFF"
if (tm in ["heat","emergency heat","auto"]) {
// heater
if (heatingSetpoint - currentTemp >= threshold) {
thermostat.setHeatingSetpoint(ct + 2)
log.debug "thermostat.setHeatingSetpoint(${ct + 2}), ON"
else if (currentTemp - heatingSetpoint >= threshold && thermostat.currentHeatingSetpoint - ct >= threshold) {
thermostat.setHeatingSetpoint(ct - 2)
log.debug "thermostat.setHeatingSetpoint(${ct - 2}), OFF"
else {
thermostat.setHeatingSetpoint(heatingSetpoint)
thermostat.setCoolingSetpoint(coolingSetpoint)
thermostat.poll()
// for backward compatibility with existing subscriptions
def coolingSetpointHandler(evt) {
log.debug "coolingSetpointHandler()"
def heatingSetpointHandler (evt) {
log.debug "heatingSetpointHandler ()"
