How would I use the association group to control a nearby zwave outlet?
Use case: 26933 switch is installed in a room that has a zwave outlet, when the light is on the outlet should be on, when the light is off the outlet off.
Matt,
Should line 610 of the device handler replicated below be size:2 instead?
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,settings.resetcycle.toInteger()], parameterNumber: 15, size: 1)
Thanks,
B
Use the IDE to determine the network ID of your switch⊠It will be a two digit Hexadecimal number.
If you havenât added the community provided DTH for this device, add it and configure it for your motion switch.
Click the configuration icon (gear in the top right) then scroll down to Association Groups. Add the network ID of your outlet (that you grabbed above)
Save and exit.
Group 2 associated zwave devices dhould get a command to turn on and off with the switch itself.
Group 3 works with the double tap function.
Is it possible to use double tap to trigger a virtual switch? Iâm trying right now and it doesnât seem to work. The device type is âSimulated Switchâ. Maybe it needs to be something else?
Not with Z-Wave association groups. For association groups, the target device MUST be a physical Z-wave switch. If you want to target a virtual switch, you need to use something like a ST Routine or a SmartApp like Advanced Button Controller to trap and respond to the button 1 (up, on) or 2 (down, off) press event.
I see. I have WebCoRE running a âBright Modeâ. Virtual switch that disables any circadian stuff and turns the bulbs to 100% and bright white. Iâd like to trigger this with the 26933 double tap.
Both Advanced Button Controller and the ST Routines only show Two buttons available with the 26933. Shouldnât there be 4 if double tap is available?
Nope - There are the âonâ and âoffâ switches, and the buttons 1 and 2. Button 1 corresponds to the DT Up and Button 2 corresponds to DT Down. So you associate whatever you want to turn ON with DoubleTap up with Button 1.
It looks something like this:
Happy Button.
Iâll be danged, there it is. Finally! Thanks!
A little tweaking necessary - it wants to turn the virtual switch on along with the regular on/off. I think it might still be associated in group 3? Going to try to clean it up with zwave tweaker.
Unfortunately Iâm still having trouble. The regular on/off of the switch is inexplicably tied up together with double tap buttons 1 and 2. I can double tap to turn on the virtual switch and it will work, but if I double tap to turn it off, it will turn off but then immediately turn back on. At that point the original on/off state of the 26933 switch is no longer functional and the switch remains in the on position until I remove all rules involving doubletap buttons 1 & 2. Tried this both with Advanced Button Controller as well as a WebCoRE piston.
Zwave Tweaker still says it is associated to the original device ID of the virtual switch in group 3. Iâm unsure how to reset/remove that association, so I just changed the device ID of the virtual switch to something different. Could this be the culprit?
Okay Iâm realizing whatâs happening here. There is no doubletap happening at all. âButton Oneâ is not the doubletap as you said. Itâs just the On button on the physical switch. So far there is no evidence of double tap working here.
Thatâs strange - not at all how my six, 14xxx switches are working⊠And I just rechecked my 26933, it works just like my 14xxx
Most reports in this thread confirm doubletap not working with this model⊠Did something change?
I have a 14 which works as expected, but I have it directly associated with another Z+ device, not a virtual switch.
nathancu, can you post your firmware version? I wonder if thereâs more than one batch of these.
Will do. Give me a bit - Iâm not where I can get to the IDE at the moment.
How hard would this DTH be to modify for a Zooz dimmer? Namely, the ZEN24: https://www.amazon.com/ZEN24-VER-2-0-Existing-Mechanical/dp/B01N0GWI83
The functionality of the ZEN24 is different than the one for the Motion Dimmer. Weâll be releasing a Zooz motion-activated switch (not a dimmer) later this spring, the model number is ZEN12 and it will have its own dedicated handler. Meanwhile, the ZEN24 has a handler created for it but since its only configuration option is to reverse up/down operation, it will probably not come useful to you. Is there anything in particular youâre looking to apply the handler for?
Sorry it took so long, had an issue I needed to take care ofâŠ
Itâs:
zw:L type:1101 mfr:0063 prod:494D model:3034 ver:5.27 zwv:4.34 lib:03 cc:5E,72,5A,73,26,27,2B,2C,70,86,71,60,8E,85,59,7A,56 role:05 ff:8600 ui:8600 ep:[â1101 5E,59,26â, â0701 5E,59,71â]
So itâs a v. 5.27
You now have me curious as to what Iâm getting so Iâm going to setup a test later. I canât do it till this weekend though.
Modifying the default âonâ brightness level depending on the time of day. If I tap âupâ once on the ZEN24 in the middle of the night, itâd be nice to have it turn on at say 40% brightness, even if it was 100% brightness the last time it was used (before going to bed).
Looks like ours are identical.
Unfortunately, this canât be accomplished with the current version of the switch. It will always go to the last brightness level when turned on manually. But weâll keep it in mind for future releases!
