I’ve done this install with a Jasco dimmer switch and add-on dumb switch a handful of times before. However, I’m struggling with the one I’m working on. I’ve tested the wires and found the LINE wire where I assume the active switch goes:
The red circles are hot and both of those wires come from the same romex. In the old switch, both white wires were twisted together and went to the traveler screen. I assume the black hot black wire is the LINE to the breaker box. So what is the hot white wire and why was it twisted up with the other white wire? I assume the cold black and white wires go to the other switch or the fixture?
All wires in the other box are cold. The white wire went to the traveler on the old switch. All come from the same romex. So where is the other end of that red wire? When I turn the switch on in the other box, the black wire gets hot, so that’s the LINE to this box. The white wire, which I believe to be the traveler, also gets hot.
In the box behind the fixture, there are just black and white wires.
Any help here would be greatly appreciated. I spent too much time yesterday banging my head against the wall! Thanks in advance!
