Issues Writing Edge Driver for WIFI Sensors
I have a Tasmota Smart Meter Reader, at first I had the problem that the Matter integration with Smartthings didn’t work, so I thought I’d just write my own driver and use HTTP requests. That’s what I did. The only problem is that I somehow fail because of the following problems:
  1. automatic updates → I can only update the values of the electricity meter manually, but actually I want the value to be updated automatically in order to execute routines and have a diagram.
  2. the diagram only has a division into hours and days, but actually I would also like to have a division into minutes, as is the case with the Aeotec Motion Sensor, for example.
    How can I solve these problems?
I’m not yet very familiar with Smartthings drivers, which you can probably tell from the code.
Many thanks in advance!
init.lua
-- require st provided libraries
local capabilities = require "st.capabilities"
local Driver = require "st.driver"
local log = require "log"
-- require custom handlers from driver package
local command_handlers = require "command_handlers"
local discovery = require "discovery"
-- local functions
-- this is called once a device is added by the cloud and synchronized down to the hub
local function device_added(driver, device)
  log.info("[" .. device.id .. "] Adding new Smart Meter device")
end
-- this is called both when a device is added (but after `added`) and after a hub reboots.
local function device_init(driver, device)
  log.info("[" .. device.id .. "] Initializing Smart Meter device")
  -- mark device as online so it can be controlled from the app
  device:online()
end
-- this is called when a device is removed by the cloud and synchronized down to the hub
local function device_removed(driver, device)
  log.info("[" .. device.id .. "] Removing Smart Meter device")
end
-- create the driver object
local smi_driver = Driver("smart_meter", {
  discovery = discovery.handle_discovery,
  lifecycle_handlers = {
    added = device_added,
    init = device_init,
    removed = device_removed
  capability_handlers = {
    [capabilities.refresh.ID] = {
      [capabilities.refresh.commands.refresh.NAME] = command_handlers.refresh,
-- run the driver
smi_driver:run()
command_handlers.lua
local cosock = require "cosock"
local http = cosock.asyncify "socket.http"
local json = require("dkjson")
local command_handlers = {}
function get_sml_current_consumption(value)
  -- Ein Muster, um die SML Current consumption zu finden
  local pattern = "{s}SML Current consumption {m}(.-) W{e}"
  -- Eine Variable, um das Ergebnis zu speichern
  local result = nil
  -- Eine Schleife, um das Muster im Wert zu suchen
  for match in string.gmatch(value, pattern) do
    -- Das Ergebnis auf den gefundenen Wert setzen
    result = match
    -- Die Schleife beenden
    break
  end
  -- Das Ergebnis zurückgeben
  return result
end
function command_handlers.refresh(driver, device, command)
  log.info("status wird aktuallisiert")
  local response = http.request("http://192.168.178.105/?m=t")
  local power = get_sml_current_consumption(response)
  log.info("Aktueller Verbrauch: "..power.."W")
  device:emit_event(capabilities.powerMeter.power({value = tonumber(power), unit = "W"}))
end
return command_handlers
profil.yaml
components:
- id: main
  capabilities:
  - id: powerMeter
    version: 1
  - id: refresh
    version: 1
  categories:
  - name: CurbPowerMeter
Tagging @nayelyz
have you looked at her profile recently? :slight_smile:
tagging @AlejandroPadilla
Hi @Hellerqr
for the first question, the easy way to do it automatically is using call_with_delay on the driver something like
device.thread:call_on_schedule(5.0, function ()
 end)
and with this, the hub will update the values depending on the seconds you define, another option is that your devices work also as server something like this https://github.com/SmartThingsDevelopers/SampleDrivers/blob/main/lightbulb-lan-esp8266/driver/src/server.lua but I’m not very familiar with it sorry :sweat_smile:
for the second question, I think it is more related more with the presentation and how the app generates it.
postdata: thanks for the help @milandjurovic71 @jkp
I have now solved the problem by loading a script onto the sensor that sends the current value to the Smartthings Hub once every 5 seconds. I found it easier.
Thanks for the answer anyway.
