I need to post a 52k xml data and I keep getting a weird error when trying to send that data with the httpPost() API. I am able to send smaller sizes of data just fine with the API just that when its huge the API fails.
From a device handler I call a parent App method to do the httpPost, when I do that the App stops logging and the device handler shows this error at the point of the call to the parent:
java.lang.reflect.UndeclaredThrowableException @line 175 (poll)
I do have a try catch block around the call to httpPost but it is not catching anything. If I comment out the call to httpPost I don’t see this error. Again: the same code works fine when using a smaller body.
BTW, the public POST API I need to hit cannot be modified.
Any tips on getting around this problem is appreciated.
