Hi,
I am using Sharptools and tasker to set up some tasks.
I can use the setLevel command to set the level of the light if I just input a value into the paramaters box, e.g. 15. However I am unable to set the level of the lights by using a variable.
e.g. if I use variable set to set %level to 5, and then put %level in the parameters box. When I run the task nothing happens.
Do I have to do something different if I am using a variable rather than just typing in the number? .
