Is there a third party inexpensive remote control for Amazon echo Dot 2nd generation?
What would the remote be controlling? Do you need to control the Dot itself from another room when it canāt hear you directly?
Or do you mean the equivalent of a remote that the dot could control to then activate other devices like a TV?
Just the Echo Dot.
I am not aware of any 3rd party device for thisā¦
Yes I realize that is the one from Amazon, I was looking for a third party one.
Thereās no third-party hardware device that Iām aware of, but you can use the Roger app (which is free) on any android or iOS device. So you can use it on your existing phone or you can buy a cheap android phone for it.
edited to update
Now that I look at it closer, it may be that Roger only let you access the voice service, not the specific device, so it might not meet your needs. Sorry for any confusion. My bad.
Another one you can use is:
You might want to consider the Roger app as well which can communicate with your Echoās.
Yep, canāt find either for IOS. The Rodger app on IOS is a group Walkie Talkie. OK this is the app, I will try it out now. Thanks all.
I would think your voice is the most inexpensive remote for the Echoās no?
Itās a group walkie-talkie, but if you follow the link that I gave you you can also talk to the Alexa voice service as one of your contacts. I just donāt know if you can specify the exact Dot or not.
Choose ābotsā inside the Roger app and you can add Alexa as a contact. But I donāt think itās specific to one of your dots, I think youāre just talking to the voice service
Thanks that does the job. But I think I might invest in the regular remote or the Logitech one.
Logitech one? You donāt mean the Harmony I assume? What are you trying to control? The Alexa app works as a great remote for audio control and volume control.
Just want a way to turn lights adjust temp from a room with no Echo installed.
For that, Roger or similar app should be the easiest. ![]()
Any old phone or tablet running the Alexa app.
I do have an amazon remote that came with my original echo, Iāve used it as you intend but the room was just far enough away to go in and out of BT range, so it worked pretty well but not consistently. Roger, being wifi to the AWS cloud would work regardless. It isnāt as simple of course so I understand now why youād want the remote.
Iāve found this app. to be handy as an alternative way to control my dot.
https://reverb.ai
Doesnāt work for me on Android, but perhaps thatās because Iām in the UK and this is US only ?
All I get is āSomething went wrong. Please try againā
I downloaded the app and it works with one problem! It is using PST as time zone not EST for me. I tried the web interface and that works on my iPhone. Thanks for the heads up.
