Hello community,
I am working on some smart home planning and had a couple of questions.
- Can button single click (up/down) be reprogrammed on the HS-WD100+ / HS-WD200+ / HS-WS100+ / HS-WS200+ not to power or to cut power to the circuit - just to be programmable actions? (Concept: Hue bulbs)
- Can button hold (up/down) be be reprogrammed on the HS-WD100+ / HS-WD200+ not to change the power delivered to the circuit - just to be a programmable action? (Concept: Act as a dimmer for a Hue bulb)
Essentially, I want to see if I can cause the HomeSeer HS-WD/WS series to keep power to Hue bulbs for all operations except when the airgap switch is pulled. The concept is so that they can be general purpose smart switches with the airgap as an emergency backup for network outages, changing lightbulbs, etc.
I saw that @Darwin has written an excellent driver from it, which looks to me like the program is doing the setting for these cases, but I wanted to check to be sure.
