I’m not sure if this is true. This is just from experiential observations. If you are running a sunset or sunrise app only in a specific mode, it may not fire. My theory is if you have it running only during your “Home” mode, then when you’re in “Sleep” mode and your app is supposed to schedule a sunrise or sunset time, the app won’t schedule those times.
For me to make it work, I have two modes for each mode. For example: “Home” and “Home - Dark”, “Away” and “Away - Dark”, etc… Then I have an app that runs in all modes to run a sunset and sunrise schedule and just switches between the mode sets. Here’s the app that I wrote for it:
* Better Sunrise/Sunset
* Copyright 2014 Eric Roberts
definition(
name: "Better Sunrise/Sunset",
namespace: "baldeagle072",
author: "Eric Roberts",
description: "Better sunrise/sunset with more options",
category: "Mode Magic",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
//setup
preferences {
page name:"setupInit"
page name:"setupConfigure"
page name:"setupModeTypes"
def setupInit() {
TRACE("setupInit()")
if (state.installed) {
//return setupModeTypes()
return setupConfigure()
} else {
def setupConfigure() {
TRACE("setupConfigure()")
def textNumOfHelp =
"You can switch between two modes for each type. How many types " +
"do you have?"
def inputNumModeTypes = [
type: "number",
title: "How many mode types?",
defaultValue: "3",
required: true
def pageProperties = [
title: "Number of Mode Types",
nextPage: "setupModeTypes",
uninstall: true
install: true,
uninstall: false
return dynamicPage(pageProperties) {
section("Number of Mode Types") {
paragraph textNumOfHelp
input inputNumModeTypes
section ("Sunrise offset (optional)...") {
input "sunriseOffsetValue", "text", title: "HH:MM", required: false
input "sunriseOffsetDir", "enum", title: "Before or After", required: false, options: ["Before","After"]
section ("Sunset offset (optional)...") {
input "sunsetOffsetValue", "text", title: "HH:MM", required: false
input "sunsetOffsetDir", "enum", title: "Before or After", required: false, options: ["Before","After"]
section ("Zip code (optional, defaults to location coordinates)...") {
input "zipCode", "text", required: false
section("Light Sensor (optional)") {
input "lightSensor", "capability.illuminanceMeasurement", title: "Which Light Sensor?", required: false
input "lightLevel", "number", title: "Light Level?", default: 500
section( "Notifications" ) {
input "sendPushMessage", "enum", title: "Send a push notification?", options: ["Yes", "No"], required: false
input "phoneNumber", "phone", title: "Send a text message?", required: false
def setupModeTypes() {
TRACE("setupModeTypes()")
def textDayHelp =
"This mode will be active during the day"
def textNightHelp =
"This mode will be active at night"
def textOnSunriseHelp =
"These switches will turn on at sunrise"
def textOffSunriseHelp =
"These switches will turn off at sunrise"
def textOnSunsetHelp =
"These switches will turn on at sunset"
def textOffSunsetHelp =
"These switches will turn off at sunset"
title: "Configure Mode Types",
install: true,
uninstall: state.installed
for (int n = 1; n <= numModeTypes; n++) {
section("Mode Type ${n}", hideable:true, hidden:true) {
paragraph textDayHelp
input "m${n}_dayMode", "mode", title: "Day Mode", required: true
paragraph textNightHelp
input "m${n}_nightMode", "mode", title: "Night Mode", required: true
paragraph textOnSunriseHelp
input "m${n}_sunriseOnSwitches", "capability.switch", title: "Sunrise On Switches", multiple: true, required: false
paragraph textOffSunriseHelp
input "m${n}_sunriseOffSwitches", "capability.switch", title: "Sunrise Off Switches", multiple: true, required: false
paragraph textOnSunsetHelp
input "m${n}_sunsetOnSwitches", "capability.switch", title: "Sunset On Switches", multiple: true, required: false
paragraph textOffSunsetHelp
input "m${n}_sunsetOffSwitches", "capability.switch", title: "Sunset Off Switches", multiple: true, required: false
// installed/updated/init
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
TRACE("initialize()")
state.installed = true
if (settings.zipCode == null) {
settings.zipCode = location.zipCode
state.numModeTypes = numModeTypes
state.sunriseArray = []
state.sunsetArray = []
state.modeTypes = []
setupModeType(n)
//log.debug("init modeTypes ${state.modeTypes}")
if (lightSensor) {
subscribe(lightSensor, "illuminance", lightHandler)
scheduleSunriseSunset()
TRACE("End init")
def setupModeType(n) {
TRACE("setupModeType($n)")
def modeType = [:]
modeType.dayMode = settings."m${n}_dayMode"
modeType.nightMode = settings."m${n}_nightMode"
state.modeTypes.push(modeType)
state.sunriseArray.push(modeType.nightMode)
state.sunsetArray.push(modeType.dayMode)
def getModeTypeDevices(n) {
if (n >= state.numModeTypes) {
return null
n++
def devices = [:]
devices.sunriseOnSwitches = settings."m${n}_sunriseOnSwitches"
devices.sunriseOffSwitches = settings."m${n}_sunriseOffSwitches"
devices.sunsetOnSwitches = settings."m${n}_sunsetOnSwitches"
devices.sunsetOffSwitches = settings."m${n}_sunsetOffSwitches"
return devices
// schedule
def scheduleSunriseSunset() {
TRACE("scheduleSunriseSunset()")
def srOff = sunriseOffset()
def ssOff = sunsetOffset()
log.debug("srOff: $srOff , ssOff: $ssOff")
def sunriseSunset = getSunriseAndSunset(zipCode: settings.zipCode)
def sunriseTime = sunriseSunset.sunrise
def sunsetTime = sunriseSunset.sunset
def sunriseScheduleTime = getSunriseWithOffset(srOff)
def sunsetScheduleTime = getSunsetWithOffset(ssOff)
log.debug("sunriseScheduleTime $sunriseScheduleTime , sunsetScheduleTime $sunsetScheduleTime")
def localData = getWeatherFeature('geolookup', settings.zipCode as String)
def timezone = TimeZone.getTimeZone(localData.location.tz_long)
log.debug( "Sunset today is at $sunsetTime" )
log.debug( "Sunrise today is at $sunriseTime" )
unschedule()
schedule(sunriseScheduleTime, sunrise)
schedule(sunsetScheduleTime, sunset)
schedule(timeTodayAfter(new Date(), '01:00', timezone), scheduleSunriseSunset)
def getSunriseWithOffset(srOff) {
def srOffTime = getSunriseAndSunset(zipCode: settings.zipCode, sunriseOffset:srOff)
//log.debug(srOffTime)
return srOffTime.sunrise
def getSunsetWithOffset(ssOff) {
def ssOffTime = getSunriseAndSunset(zipCode: settings.zipCode, sunsetOffset:ssOff)
return ssOffTime.sunset
def sunriseOffset() {
//log.debug("settings.sunriseOffsetValue ${settings.sunriseOffsetValue}")
//log.debug("settings.sunriseOffsetDir ${settings.sunriseOffsetDir}")
if ((settings.sunriseOffsetValue != null) && (settings.sunriseOffsetDir != null)) {
def offsetString = ""
if (settings.sunriseOffsetDir == 'Before') {
offsetString = "-"
offsetString += settings.sunriseOffsetValue
return offsetString
} else {
return "00:00"
def sunsetOffset() {
//log.debug("settings.sunsetOffsetValue ${settings.sunsetOffsetValue}")
//log.debug("settings.sunsetOffsetDir ${settings.sunsetOffsetDir}")
//log.debug((settings.sunsetOffsetValue != null) && (settings.sunsetOffsetDir != null))
if ((settings.sunsetOffsetValue != null) && (settings.sunsetOffsetDir != null)) {
if (settings.sunsetOffsetDir == 'Before') {
offsetString = "-"
offsetString += settings.sunsetOffsetValue
return offsetString
} else {
return "00:00"
// events
def lightHandler(evt) {
log.debug "Light Level: ${evt.value}, Set: ${lightLevel}"
def sunrise() {
TRACE("sunrise()")
def currentMode = location.mode
def n = state.sunriseArray.indexOf(currentMode)
log.debug("currentMode $currentMode sunriseArray ${state.sunriseArray}")
if (n >= 0) {
def modeType = state.modeTypes[n]
log.debug("sunrise modeType $modeType")
def devices = getModeTypeDevices(n)
def onSwitches = devices.sunriseOnSwitches
def offSwitches = devices.sunriseOffSwitches
if (onSwitches != null) {
onSwitches.on()
if (offSwitches != null) {
offSwitches.off()
changeMode(modeType.dayMode)
def sunset() {
TRACE("sunset()")
def n = state.sunsetArray.indexOf(currentMode)
if (n >= 0) {
def onSwitches = devices.sunsetOnSwitches
def offSwitches = devices.sunsetOffSwitches
onSwitches.on()
offSwitches.off()
changeMode(modeType.nightMode)
def changeMode(newMode) {
if (newMode && location.mode != newMode) {
if (location.modes?.find{it.name == newMode}) {
setLocationMode(newMode)
log.debug("has changed the mode to '${newMode}'")
else {
log.debug("tried to change to undefined mode '${newMode}'")
// debug
def TRACE(msg) {
log.debug msg
//log.debug("state $state")
It’s been working for me for over a month. Let me know if this works for you.
