Is there a way to do validation of the inputs when the user presses Done?
There is a ârequiredâ argument for inputs. Hereâs an example:
input "dayMode", "mode", title: "Day Mode", required: true
@baldeagle072 I am familiar with the required; together with ability to specify a capability, it gives you a rudimentary level of validation.
I have two inputs to specify multiple devices. I would like to confirm that the number of devices specified in the first input is equal to the number of devices specified in the second input.
There could be many more uses.
The first thing that comes to mind is using dynamic pages. It wonât be the most elegant validation, but it could work. You could try something like this:
preferences {
page name:"setup"
page name:"validate"
def setup() {
def pageProperties = [
title: "Setup",
nextPage: "validate",
uninstall: false
return dynamicPage(pageProperties) {
input "devices1", "capability.switch", title: "Devices 1", required: true
input "devices2", "capability.switch", title: "Devices 2", required: true
def validate() {
if (devices1.size() == devices2.size()) {
title: "Validated",
install: true,
uninstall: true
text "Hit 'Done' to install"
} else {
title: "Not Validated",
install: false,
uninstall: true
text "The number of devices don't match"
href "setup", title:"Go Back", description:"Tap to go back"
Let me know if this works!
@baldeagle072 This is close to perfect. I did make some changes:
- I added multiple: true to the input statements
- I got an error when using âtextâ; I use âparagraphâ instead
- rather than using âhrefâ to go back to setup, I use ânextPage: setupâ. Interestingly, the âDoneâ button, rather than the âNextâ button is displayed for the last page, even if ânextPageâ is used.
This is my code:
def validatePage() {
if (virtual.size() == physical.size()) {
title: "Validation",
install: true,
uninstall: true
section() {
paragraph "Press 'Done' to complete Setup"
} else {
nextPage: "setupPage",
install: false,
uninstall: true
section() {
paragraph "The number of devices don't match. Press 'Done' to correct the selected devices."
