Is there a trick to adding this fob and/or device type? I’ve added several other custom Zwave device types and physical devices in the past year, without too much trouble. But I’ve RARELY gotten a custom zigbee device to just work. n.b. I am mostly a cut-and-paste monkey, not a ST developer.
The standard devices (e.g. presence sensors and Centralite Plugs) work fine. The 3button(Smartenit ZigBee HA Wireless 3-Button Switch/ST-integration) is unreliable (in my experience) but sometimes works anyway.
Another zigbee keyfob, the Securify 4button seemed promising. The hub-v1 showed the join events, and I could modify the device to the custom device type, but the smartapp button controller never saw any button presses from the device.
Now this zigbee keyfob (Iris 3450L) ALSO joins the hub-v1, and I can update the device type (which I saved from mitchponds’s top-post and self-published without issues), but neither the hub log nor the button controller live log, sees any button presses to act upon.
Any ideas?
LATER, THANKS @Sticks18. As you suggested the reset procedure is key. The actual procedure is still not clear to me but pressing TWO buttons (top 2 in my case) WHILE inserting battery, performed a reset and rejoin. The confirmation was green light during the 2-press then upon releasing, a fast-flashing blue.
I was also doing a phoneapp-Connect-New-Device but I don’t know if that matters.
Now I can see button-presses in the hub log.
Sorry about the fuzzy notes - I’m really just recording this for next time I have a moment to mess with this again.
