SmartThings Community
Iris Motion Sensor (2nd gen, 3326-L)
dth_motionsensor
dth_sensors
(Jason "The Enabler" as deemed so by @Smart) #323
If my memory serves me correctly, which it probably doesn’t… but I believe ST see a 2.7 as the low end of the battery life.
Maybe @JDRoberts remembers what that range is.
(Jason "The Enabler" as deemed so by @Smart) #324
I had a battery reading 1% yesterday. I swapped it out and just threw it away. It was the original battery and was about 2 years old…
I hate this battery issue for everyone, those things are not cheap at all.
(Robert M) #325
On my multimeter, a new CR2 battery like the one I use in my Iris sensors registers around 3.2V (with my multimeter set to 20V DC). By the time it gets close to 3.0, it’s practically dead. I don’t recall what exact values correspond to ST’s battery percentage reporting, but lithium batteries don’t decline in voltage in a linear fashion–see, for example: http://data.energizer.com/pdfs/cr2_eu.pdf. This makes it difficult for the DTH to predict remaining capacity based on voltage, especially since it plateaus for a bit after a slight initial dropoff and a sharp final dropoff if it’s even still usable at that point. I’d be hesitant to rely on ST’s reporting given this difficulty.
(My multimeter might be reading this all a bit high; I’m not sure how well calibrated it is for these voltages—certainly appears to be a bit higher new than on the Energizer chart above—so if you have one you may want to test when new and “dead” to compare.)
(Seth Daniel) #326
Does anyone know if this works for the 3326-L2? These are currently on sale at Lowe’s for $15, and I’d like to buy several, but I want to ensure they work with SmartThings first.
(Jimmy) #327
If what works? They work out of the box now.
(Seth Daniel) #328
This thread seems to be about the 3326-L model.
https://www.lowes.com/pd/Iris-Motion-Sensor-Works-with-Iris/999925310
There is also a 3326-L2 model, which I don’t see mentioned in many places.
https://www.lowes.com/pd/Iris-Motion-Sensor/1000321971
I’m currions if the -L2 works in addition to the -L. I’m guessing the answer is yes, since it seems to be a new version of the same sensor, but I’m not sure if there’s an important difference for SmartThings compatibility.
(Jimmy) #329
They’re the same sensor, only difference is the packaging
#330
Well, a couple days ago had another one go into meltdown mode and start registering false motion every minute or so. Replaced the battery but then sadly another for the waste bin.
