Iris Gen 2 devices?
I have a seller on Ebay that gave me a coupon for his store. I’m looking at some Iris stuff. Is it only Iris Gen 1 and 2 stuff that works with smartthings or all generations?
IIRC its gen 2 and 3. If you can post a pic of the device we can let you know.
I have been using IRIS motion and contact sensors for a number of years. The ones I use are the iL07 motion with the ST Zigbee Motion Sensor driver and it provides motion, temperature and humidity with temp and humidity offset settings. I also use the 3320 contact sensors with the Zigbee ContactMC driver. It provides contact status and tempature with temp offset, temp interval and temp report change. Both of them work extremely well and the battery last a good 6-8 months in high use areas and longer in low use areas.
I believe the breakdown is as follows:
Motion Sensor
3326-L = Gen 2 & iL07-1 = Gen 3
Contact Sensors
3320-L = Gen 2 & iL06-1 = Gen 3
I have read on other forums that the gen 1 have issues due to the lack of standards back then and they frequently disappear.
Thank you, I did reply with pictures and links but someone named Akismet temporarily blocked it for some reason. I’m new and maybe I’m not allowed to post pictures for some reason. I see an automation kit and a lighting kit with those motion sensors and contact sensors. I also see plugs that say 3210-l. the seller gave me a 10% off coupon (maxnetwork10) so I think I may grab some. I dont have a very stable Zigbee mesh and maybe the plugs will help.
These still work correct? I did read about the change to edge drivers.
Yes the 3210-L produced by IRIS and Centralite will work. Yes Zigbee devices connected to mains power will act as a repeater. One nice thing about these is it has a power meter so you can set up automations based on power use. The downside is they are rather large and will cover both outlets on a normal 2 outlet plug. There are other options with power meter that don’t cover both outlets.
Thank you, what about the Lot of 2 Samsung SmartThings Sensors I linked to, still work after the Edge switch or?
Yes, these definitely work.
Thank you.
Got 2 of the 3210-L plugs for 24 bucks, they work perfectly fixed my Zigbee mesh issue and seem to be working as Zwave repeaters as well.
I have had about 5 of these that I got years ago and they all seem to be working. I added the 2 new ones to get my Zigbee and Zwave mesh into the garage.
