I’m looking for assistance on how to do intervals for a humidifier I’ve got placed in my mushroom tent. Currently upgraded my system with a very powerful humidifier which takes about 1min for the tent to reach 100% humidity. I’m needing a 1min on and a 30 min off interval program. Does anyone know of a smart program that can do this?
If you don’t come across a smartapp that does this, the way I would set it up is to create a virtual switch and set up a bunch of smart lighting automations:
- turn the virtual switch on when the outlet turns off;
- turn the outlet on when the virtual switch turns off;
- power allowance turns the outlet off after 1 minute;
- power allowance turns the virtual switch off after 29 minutes.
These automations should trigger each other and run in a continuous cycle.
I did this by creating 2 automations for the same outlet:
- If outlet is on, turn it off, but delay this action for 1 minute.
- If outlet is off, turn it on, but delay this action for 30 minutes.
As a result your outlet will switch on for one minute every 30 minutes.
This is clever.
