Of course! It’s the car lot theory. Car makes a sound all day long… get it to the car lot and it behaves. When I hit refresh (about the 100th time since I installed). The logs showed a lot and the temperature changed. I did make one change, I set debug level from high to low so maybe that did it. Anyway, the logs as you requested.
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:13 AM: debug <<<<< dly:1000/1000
<<<<< Event: [value:0, displayed:true, name:powerlevel, isStateChange:false, linkText:Pool, descriptionText:Pool powerlevel is 0]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:13 AM: debug >>>>> PowerlevelReport(powerLevel: 0, timeout: 0) - description:zw device: 27, command: 7303, payload: 00 00
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:12 AM: debug <<<<< dly:1000/1000
<<<<< Event: [name:epEvent, value:5:250300, isStateChange:true, displayed:true, descriptionText:(fwd to ep 5), linkText:Pool]
<<<<< Event: [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off), linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:12 AM: debug >>>>> MultiInstanceCmdEncap(command: 3, commandClass: 37, instance: 5, parameter: [0]) - description:zw device: 27, command: 6006, payload: 05 25 03 00
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:11 AM: debug <<<<< dly:1000/1000
<<<<< Event: [name:epEvent, value:4:250300, isStateChange:true, displayed:true, descriptionText:(fwd to ep 4), linkText:Pool]
<<<<< Event: [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off), linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:11 AM: debug >>>>> MultiInstanceCmdEncap(command: 3, commandClass: 37, instance: 4, parameter: [0]) - description:zw device: 27, command: 6006, payload: 04 25 03 00
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:10 AM: debug <<<<< dly:1000/1000
<<<<< Event: [name:epEvent, value:3:250300, isStateChange:true, displayed:true, descriptionText:(fwd to ep 3), linkText:Pool]
<<<<< Event: [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off), linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:10 AM: debug >>>>> MultiInstanceCmdEncap(command: 3, commandClass: 37, instance: 3, parameter: [0]) - description:zw device: 27, command: 6006, payload: 03 25 03 00
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:09 AM: debug <<<<< dly:1000/1000
<<<<< Event: [name:epEvent, value:2:250300, isStateChange:true, displayed:true, descriptionText:(fwd to ep 2), linkText:Pool]
<<<<< Event: [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off), linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:09 AM: debug >>>>> MultiInstanceCmdEncap(command: 3, commandClass: 37, instance: 2, parameter: [0]) - description:zw device: 27, command: 6006, payload: 02 25 03 00
<<<<< Event: [name:epEvent, value:1:250300, isStateChange:true, displayed:true, descriptionText:(fwd to ep 1), linkText:Pool]
<<<<< Event: [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off), linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:09 AM: debug >>>>> MultiInstanceCmdEncap(command: 3, commandClass: 37, instance: 1, parameter: [0]) - description:zw device: 27, command: 6006, payload: 01 25 03 00
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:06 AM: debug <<<<< dly:1000/1000
<<<<< Event: [name:epInfo, value:["10012527","100025","100025","100025","100025","100025","110025"], displayed:true, descriptionText:, isStateChange:false, linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:06 AM: trace createEndpointInfo(5) endpointCnt=7
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:06 AM: debug >>>>> MultiInstanceReport(commandClass: 37, instances: 5, res11: false) - description:zw device: 27, command: 6005, payload: 25 05
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:05 AM: debug <<<<< dly:1000/1000 No Commands or Events
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:05 AM: debug >>>>> AssociationGroupingsReport(supportedGroupings: 1) - description:zw device: 27, command: 8506, payload: 01
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:04 AM: error java.lang.NullPointerException: Cannot invoke method format() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:04 AM: debug -->Version: VersionReport(applicationSubVersion: 1, applicationVersion: 3, zWaveLibraryType: 6, zWaveProtocolSubVersion: 78, zWaveProtocolVersion: 2)
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:04 AM: debug >>>>> VersionReport(applicationSubVersion: 1, applicationVersion: 3, zWaveLibraryType: 6, zWaveProtocolSubVersion: 78, zWaveProtocolVersion: 2) - description:zw device: 27, command: 8612, payload: 06 02 4E 03 01
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:03 AM: debug <<<<< dly:1000/1000
<<<<< Event: [descriptionText:Pool: ManufacturerSpecificReport(manufacturerId: 5, manufacturerName: Intermatic, productId: 1619, productTypeId: 20549), isStateChange:true, displayed:true, linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:03 AM: warn Captured zwave command ManufacturerSpecificReport(manufacturerId: 5, manufacturerName: Intermatic, productId: 1619, productTypeId: 20549)
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:03 AM: debug >>>>> ManufacturerSpecificReport(manufacturerId: 5, manufacturerName: Intermatic, productId: 1619, productTypeId: 20549) - description:zw device: 27, command: 7205, payload: 00 05 50 45 06 53
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:03 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:03 AM: debug >>>>> ConfigurationReport(configurationValue: [255, 255, 255, 255], parameterNumber: 47, reserved11: 0, size: 4) - description:zw device: 27, command: 7006, payload: 2F 04 FF FF FF FF
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:02 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:02 AM: debug >>>>> ConfigurationReport(configurationValue: [255, 255, 255, 255], parameterNumber: 47, reserved11: 0, size: 4) - description:zw device: 27, command: 7006, payload: 2F 04 FF FF FF FF
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:01 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:01 AM: debug >>>>> ConfigurationReport(configurationValue: [255, 255, 255, 255], parameterNumber: 44, reserved11: 0, size: 4) - description:zw device: 27, command: 7006, payload: 2C 04 FF FF FF FF
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:00 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:37:00 AM: debug >>>>> ConfigurationReport(configurationValue: [255, 255, 255, 255], parameterNumber: 41, reserved11: 0, size: 4) - description:zw device: 27, command: 7006, payload: 29 04 FF FF FF FF
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:59 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:59 AM: debug >>>>> ConfigurationReport(configurationValue: [255, 255, 255, 255], parameterNumber: 38, reserved11: 0, size: 4) - description:zw device: 27, command: 7006, payload: 26 04 FF FF FF FF
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:57 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:57 AM: debug >>>>> ConfigurationReport(configurationValue: [0, 0, 0, 0], parameterNumber: 3, reserved11: 0, size: 4) - description:zw device: 27, command: 7006, payload: 03 04 00 00 00 00
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:56 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:56 AM: debug >>>>> ConfigurationReport(configurationValue: [1], parameterNumber: 2, reserved11: 0, size: 1) - description:zw device: 27, command: 7006, payload: 02 01 01
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:55 AM: error java.lang.NullPointerException: Cannot invoke method putAt() on null object
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:55 AM: debug >>>>> ConfigurationReport(configurationValue: [6, 2], parameterNumber: 1, reserved11: 0, size: 2) - description:zw device: 27, command: 7006, payload: 01 02 06 02
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:54 AM: debug <<<<< dly:1000/1000
<<<<< Event: [descriptionText:Pool: ThermostatSetpointSupportedReport(autoChangeover: null, cooling: null, dryAir: null, furnace: null, heating: null, moistAir: null, none: null), isStateChange:true, displayed:true, linkText:Pool]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:54 AM: warn Captured zwave command ThermostatSetpointSupportedReport(autoChangeover: null, cooling: null, dryAir: null, furnace: null, heating: null, moistAir: null, none: null)
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:54 AM: debug >>>>> ThermostatSetpointSupportedReport(autoChangeover: null, cooling: null, dryAir: null, furnace: null, heating: null, moistAir: null, none: null) - description:zw device: 27, command: 4305, payload: 41
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:53 AM: debug <<<<< dly:1000/1000
<<<<< Event: [value:87, unit:F, displayed:true, name:spaSetpoint, isStateChange:false, linkText:Pool, descriptionText:Pool spa setpoint is 87°F]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:53 AM: debug >>>>> ThermostatSetpointReport(precision: 0, reserved01: 0, scale: 1, scaledValue: 87, setpointType: 7, size: 1, value: [87]) - description:zw device: 27, command: 4303, payload: 07 09 57
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:52 AM: debug <<<<< dly:1000/1000
<<<<< Event: [value:59, unit:F, displayed:true, name:poolSetpoint, isStateChange:false, linkText:Pool, descriptionText:Pool pool setpoint is 59°F]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:52 AM: debug >>>>> ThermostatSetpointReport(precision: 0, reserved01: 0, scale: 1, scaledValue: 59, setpointType: 1, size: 1, value: [59]) - description:zw device: 27, command: 4303, payload: 01 09 3B
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:51 AM: debug <<<<< dly:1000/1000
<<<<< Event: [value:88, unit:F, name:temperature, isStateChange:true, displayed:true, linkText:Pool, descriptionText:Pool temperature is 88°F]
1dc6cc40-6fce-40b0-aff2-f25f556b81fa 9:36:51 AM: debug >>>>> SensorMultilevelReport(precision: 0, scale: 1, scaledSensorValue: 88, sensorType: 1, sensorValue: [88], size: 1) - description:zw device: 27, command: 3105, payload: 01 09 58
