Integration Zwave
Hello everyone, I need help with something. I have a MCO MH-S513 Zwave MCO device, which recognizes as multiswitch but when giving the command from the app, it does not actuate; however, when changing the status manually from the device the smarthing recognizes as on or off. I have an aeotec hub version 3
Can you help me with that?
What driver is the device using? To see what is going on, it would be helpful to have driver logging using the ST CLI. Download to a Linux/Windows/macOS computer and run the command “smartthings edge:drivers:logcat” then cut/paste here using the pre-formatted text option on the gear menu.
This is the driver that the hub comes with by default.
Sorry! But at this moment I can’t access the programming language.
