First thing I did and storing it on a cloud drive.
Also ordering a Pi today to see if i can do the install following the directions on my own.
The problem was Ubuntu was somehow reassigning the default SSDP port 1900 - his nodejs app was always listening for SSDP on random ports, rather than the default 1900 - thus never responding. On a second note, the SmartApp was - for an unknown reason - producing the Error page after the 10s wait, it appears that SmartThings lowered the time allowed for a page to be rendered? We decreased the number of waits for SSDP and the app then allowed him to manually enter the IP, thus going around the SSDP issue.
And I couldnât be happier. Thanks again!
I ordered a Raspberry pi and the instructions worked perfectly! I now have a backup HCH server.
Probably pushing my luck here but I am wondering if there is a device handler for DL cameras?
I only wrote DTHs for the devices I have. Never had a camera and DL was very unhelpful, so no, sorry.
Also, their motion sensors do not transmit events so you cannot use them as a motion sensor per se.
No worries⊠I think DL is approaching end of life with ATT. Support is limited and the product isnât being pushed as hard as it was when it rolled out.
Iâll give them a call as I need to see if there is any discount they can offer, finished my commitment a year ago lol. Same for uverse, they started charging me full prices, not good ;))
Please let us know what you hear⊠They are still cheaper than most other competitors.
They no longer have an over-the-phone-sales department. What?!
Itâs not end of life, my wife works for the IoT part of AT&T (Mostly connected car) but DL is discussed at times and they havenât ever said they were shutting it down. Doesnât mean youâre wrong either since they could change their minds at any time.
Doesnât surprise me. Everything is order online or walk into a store.
Did they change how you add a device to DL? I stopped buying contact sensors from them because I got tired of calling them up to have them pair it for me. Even renaming them youâd have to call them up and tell them.
Yes, nothing has been said officially but there are rumors. Primarily from the technicians supporting that line of business.
I hope they donât shut it down, Iâd have to write integrations for other systems and I donât have time lol
It will be interesting to see what they do. When they bought DirecTV they didnât shut off the uverse service, they tried to entice people to get DTV by supplying awesome bundles. I am not sure if they would just leave existing customers or if theyâd say SEE YA. If thatâs the case it would be awesome if they gave us admin access to the cisco hub that controls everything.
Ok everyone time to get creative. I am working on a project that takes emails generated from AT&T digital life events, parses the body of the email, and writes it to a database. For instance, I have all of these sensors installed by AT&T that send me email notifications when ever they are opened or closed. I want to use those emails to trigger other events on smartThings. I looked at IFTTT, but google does not let you search in the body. The body of the email is where are the real info is.
So⊠I thought it may be possible to setup a mail client and database on audrino and use the shield to interface with smartThings. How would I relay the sensor information to smartThings? Any ideas or suggestions?
I think they would likely sell it off.
Would this code work with dissconnected att service?
No it requires an active service
Iâm using "thermostat auto of"f with the door/window sensors and my understand is that it should turn off the AC if a sensor is left open for longer than X seconds. instead, its turning the AC off the second a sensor is opened. Is this a result of the magical DLife integration or am I having some other issue?
Who is implementing this auto off? The DL integration can sync up location mode and SHM at most, does not turn off thermostatsâŠ
A smart app is supposed to monitor contact sensors.When the sensors stay open for X seconds the app sends a command to turn off the thermostat. I am trying a different app and having better luck so probably coding of the original app i was using.
webCoRE can help you
You can set up a rule to shut it off if any of multiple contacts stays open. You could also turn it back on when all doors are closed
