Absolutely! Hereās what I know to pull off hand. Let me know anything else I can provide
7/16/2016, 1:49:12 AM [homecloudhub] Sending event to SmartThings: Device "GARAGE CONTROLLER" <GC0500BC4E> (type: garage-door-controller) changed its "garage-door-command-result" value from "ok" to "working"
7/16/2016, 1:49:25 AM [homecloudhub] Sending event to SmartThings: Device "GARAGE CONTROLLER" <GC0500BC4E> (type: garage-door-controller) changed its "garage-door-state" value from "closed" to "open"
7/16/2016, 1:49:25 AM [homecloudhub] Sending event to SmartThings: Device "GARAGE CONTROLLER" <GC0500BC4E> (type: garage-door-controller) changed its "garage-door-command-result" value from "working" to "ok"
7/16/2016, 1:49:29 AM [homecloudhub] Sending event to SmartThings: Device "GARAGE CONTROLLER" <GC0500BC4E> (type: garage-door-controller) changed its "garage-door-command-result" value from "ok" to "busy"
Clear
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:29 PM: info If the repository is missing the [AT&T Digital Life Garage Door Controller] device handler, please provide the device data to the author of this software so he can add it. Thank you. Device data is [[module:digitallife, data-battery:90, data-garage-door-command-result:busy, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:open, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:busy, data-ping-results:null, data-status:0]]
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:29 PM: info Home Cloud Hub discovered a device that is not yet supported by your hub. Please find and install the [AT&T Digital Life Garage Door Controller] device handler from https://github.com/ady624/HomeCloudHub/tree/master/devicetypes/ady624
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:29 PM: info Received update event for module digitallife, device GARAGE CONTROLLER, value busy, data: [module:digitallife, data-battery:90, data-garage-door-command-result:busy, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:open, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:busy, data-ping-results:null, data-status:0]
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:25 PM: info If the repository is missing the [AT&T Digital Life Garage Door Controller] device handler, please provide the device data to the author of this software so he can add it. Thank you. Device data is [[module:digitallife, data-battery:90, data-garage-door-command-result:ok, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:open, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:ok, data-ping-results:null, data-status:0]]
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:25 PM: info Home Cloud Hub discovered a device that is not yet supported by your hub. Please find and install the [AT&T Digital Life Garage Door Controller] device handler from https://github.com/ady624/HomeCloudHub/tree/master/devicetypes/ady624
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:25 PM: info Received update event for module digitallife, device GARAGE CONTROLLER, value ok, data: [module:digitallife, data-battery:90, data-garage-door-command-result:ok, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:open, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:ok, data-ping-results:null, data-status:0]
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:25 PM: info If the repository is missing the [AT&T Digital Life Garage Door Controller] device handler, please provide the device data to the author of this software so he can add it. Thank you. Device data is [[module:digitallife, data-battery:90, data-garage-door-command-result:working, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:open, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:open, data-ping-results:null, data-status:0]]
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:25 PM: info Received update event for module digitallife, device GARAGE CONTROLLER, value open, data: [module:digitallife, data-battery:90, data-garage-door-command-result:working, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:open, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:open, data-ping-results:null, data-status:0]
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:12 PM: info If the repository is missing the [AT&T Digital Life Garage Door Controller] device handler, please provide the device data to the author of this software so he can add it. Thank you. Device data is [[module:digitallife, data-battery:90, data-garage-door-command-result:working, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:closed, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:working, data-ping-results:null, data-status:0]]
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:12 PM: info Home Cloud Hub discovered a device that is not yet supported by your hub. Please find and install the [AT&T Digital Life Garage Door Controller] device handler from https://github.com/ady624/HomeCloudHub/tree/master/devicetypes/ady624
d6d041b6-dab8-4010-9511-e9ceb6c4b5fd 9:49:12 PM: info Received update event for module digitallife, device GARAGE CONTROLLER, value working, data: [module:digitallife, data-battery:90, data-garage-door-command-result:working, type:garage-door-controller, id:GC0500BC4E, data-rssi:0, data-location:0003037166, data-garage-door-state:closed, data-garage-door-control:null, data-test-mode-expiry:null, event:update, name:GARAGE CONTROLLER, value:working, data-ping-results:null, data-status:0]
