Alas I changed jobs so haven’t had time to look at this recently.
I haven’t done anything with the heating, cooling settings. If set to heating and the stat is set to lower than actual temperature then even though it says it’s heating, it will shut off the stat.
Iirc on / off works and just sets the stat to 4c.
I use a core piston to control the temp programme.
Can’t remember what the poll time was, it’s not that often to preserve battery life.
I will find the time to do more on this as buying some more.
Actually there aren’t, I’ve looked pretty hard. There seem to be multiple manufacturers of electronic TRVs in Europe but models that use the US z-wave frequency seem to be non-existent. Super frustrating for those of us that live in old buildings with steam radiators (like millions of people in New York City).
I am new to this and I just got my first SmartThings hub.
In the house I have several Danfoss Living Connect valves. All seem to be connected now to the hub. Ideally I would love to be able to make them behave as an On and Off switches that go to either 28 or 4 degrees.
You can control them from CORE. CORE is a smart app within smartthings that provides a lot of functionality. Best to search for it on the community. Using CORE you’ll be able to set them up to change temperatures as described at particular times of the day, through switches, motion sensors etc.
That’s exactly the setup I have. In our building multiple apartments share the boiler so the only option to control the heating is through the TRV.
I bought these Danfoss TRVs and now am able to turn heating on and off in different rooms. I do not have the main Danfoss controller as the thing is quite expensive and unnecessary I thought.
I figured out how to hook up the TRVs to the Device Type Handler from this thread. If you go to the settings of the device and change its type to the DTH from this post, you will see it as an on and off switch in the app. Just as I wanted.
So how does this work in your home? Do you have a separate temperature sensor (like Aeotec Multisensor 6) which feeds the TRV which will output a certain temperature or?
Can this be used in conjunction with a sensor from ST and or with Nest to do Room by Room heating based on some automation rules. I.e. Room 1 is below 15 degrees, heat until it hit x degrees?
That is actually my next step – reaching and maintaining specific temperature level. At the moment I only use it to turn the heating on and off in various rooms based on some presence and time of the day rules. There are a few things I am not sure about:
does the Danfos TRV allow access to its temperature sensor or do I need a separate temp sensor in each room?
none of the internet based virtual outdoor temperature tiles seem to be working for me? Is it just me or is there a working one available?
Researching things for now.
My previous hub was MiCasaVerde Vera Lite and it does not have the easiest set of tools to work with. I was hoping SmartThings would make it significantly easier to set up and control the logic.
