SmartThings Community
Integration of Argentina brand BGH A/C with smart control?
#1
Hello everyone,
I was trying to understand how to start with developments and it got really complicated.
In Argentina we have some air conditioners (their brand if BGH) with “smart control” and also a “smart control kit” which allows to control other brands’ A/C. (the smart control was designed by www.solidmation.com and both use the same app)
Such smart app has an api and I would like to know if anyone is also insterested in integrating it and how difficult this can be.
Here’s the PHP code for it: https://github.com/JoanManuelH/BHG-solidmation-PHP-REST-API/blob/master/bgh.class.php
Thank you!!
#2
Hello to the ST Community members!
I have the same problem as @Nacho1 to integrate my “BGH” air conditioner with “wifi control kit” provided by “Solidmation” with Smartthings. Since I’m not a coder, to do so I asked customer care of these brands to provide at least an IFTTT channel, but I didn’t get any response.
I tried to integrate it by using Broadlink RM2 + RM Bridge + ST Smartapp but I wasn’t able to get the IR codes from the remote (frequency issues I believe).
I also tried to mount a node.js to capture the A/C wifi commands sent by the app to my router, but that didn’t work either for me coz it was far away from my knowledge.
Since I recently found a Homebridge plugin (https://www.npmjs.com/package/homebridge-bgh-smart) which is able to control this wifi A/C unit throu PHP (https://bgh-services.solidmation.com/control/Panel.aspx) and that the user @bendews successfully wrote a ST smartapp I believe similar to the one we need ([RELEASE] Daikin WiFi Split System v1.2), I would like to ask if someone could give us a little help to achieve the integration.
Thanks in advance!
Screenshot_20180108-131042|391x500
(Adrian Marano) #3
someone has had any news about it ? The same, trying to integrate BGH (argentina) to something ( alexa google home smartthing ifttt harmony )
#4
Tagging @pizzinini
(Pablo Vigo) #5
Hi Everyone!, @Poecraft32, @pizzinini, @ [Nacho1]
Any update on it?
Regards
(Pizzinini) #6
Sorry, I missed the first tag.
You may be able to integrate via homebridge. I you set it up with a smartthings and the other one you mentioned above. I recently posted detailed instructions here:
Here is a description of how to add a 2nd plugin in the config.json file:
You can then set up a virtual switch in Smartthings that is seen in HOmebridge and write rules in Apple Home that let you control your AC.
This is all not 100% straight forwardbut may be doable with some persistente :slight_smile:
Good luck!
