# Integrating zwave or zigbee temperature sensors with Nest?
**URL:** <https://community.smartthings.com/t/integrating-zwave-or-zigbee-temperature-sensors-with-nest/29034>\
**Category:** Devices & Integrations\
**Created:** [November 14, 2015, 7:24pm UTC](https://community.smartthings.com/t/integrating-zwave-or-zigbee-temperature-sensors-with-nest/29034 "2015-11-14T19:24:57Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![yvesracine](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/yvesracine/32/95271_2.png) [@yvesracine](https://community.smartthings.com/u/yvesracine)\
**Post date:** [November 14, 2015, 7:36pm UTC](https://community.smartthings.com/t/integrating-zwave-or-zigbee-temperature-sensors-with-nest/29034/2 "2015-11-14T19:36:17Z")
</div>
Yes, I did. See this thread:
> [@\*\*\* No longer supported \*\*\* \[OBSOLETE\] Introducing ScheduleTstatZones: multi zoned heating/cooling solution for your home](https://community.smartthings.com/t/introducing-scheduletstatzones-the-ultimate-flexible-smartapp-for-your-thermostat-s-and-multi-zoned-heating-cooling-solution-for-your-home/13345):
> Hello there, \*\* UPDATE \*\* My smartapp is now officially approved by Keen Home: [image] This is the ultimate flexible smartapp for anyone who wants to better control her/his thermostat(s), and creates heating/cooling zones using Smart Vents like Econet, Keen Home vents or Ecovents. With this smartapp, you can also create “virtual zones” (without any vents) where you can then adjust the thermostat’s heating/cooling setpoints based on the avg temp calculated from different room sensors with the ‘occupied’ option or not. Actually, it should be the only smartapp that controls your thermostat(s) at home!! Latest versions: [ScheduleTstatZonesV9: new major version with added custom capability in MyVirtualZone DTH for Setting Zone setpoint under the new Samsung connect app!](https://community.smartthings.com/t/release-introducing-scheduletstatzones-multi-zoned-heating-cooling-solution-for-your-home/13345/441)[V8.8.9 EcobeeSe…](https://community.smartthings.com/t/release-introducing-scheduletstatzones-multi-zoned-heating-cooling-solution-for-your-home/13345/204)
_[View the full topic](https://community.smartthings.com/t/integrating-zwave-or-zigbee-temperature-sensors-with-nest/29034)._
