And if you have a pc/raspberry pi that is always on in your house you can setup the solution below
Been using it for a month now and its rock solid and almost instant because it connects on your LAN. Plus the coder should have the picos integrated soon (if you have the pro Lutron hub). The Official integration will be cloud to cloud and will likely not allow you to add the remotes as devices.
