Hi!
My Danfoss LC-13 radiator thermostats works well with Smartthings.
I have aslo Danfoss Room Sensor (DRS21, V07), which is a z-wave device, but unfortunately it is not listed as a SmartThings device and I am unable to insert it into SmartThings Hub.
Regarding the wished functionality the following functions shoul be supported:
- As a minimum requirement my Danfoss z-wave room sensor DRS21, V07 should be able to be inserted to see the room temperature remotely.
- As the more advanced functionality would be to set the Danfoss LC-13 through through the Danfoss room sensor DRS21, V07.
As far as I understand this function is supported with Fibaro HC2 controller as seen:
https://smarterhome.sk/en/blog/lua-danfoss-rs-thermostat_71.html.
BR
Antero
