I have the Zooz ZSE29 (Z-Wave) Outdoor Motion Detector paired with my SmartThings Hub. No problem. I have also deployed the DTH for this device via the SmartThings IDE website. No problem. I have used SmartThings Automation to turn on lights and sound an Aeotec siren when motion is detected by the ZSE 29. No problem. I have integrated the SmartThings Hub with Alexa via the Alexa app. No problem.
Here is the problem: Although the Zooz ZSE29 shows up as a device in the Alexa app, unlike the Ring motion detector that comes with the video doorbell, when I select the Zooz ZSE29 in an Alexa Routine (such as when the ZSE29 detects motion, Alexa say a custom phrase, like “Motion Detected at X” through my Echo Dot), the routine does not execute. That is, there is no message played by Alexa via my Echo Dot. In contrast, I can get Alexa to say the custom phrase through my Echo Dot with the same type of Alexa Routine when motion is detected by my Ring Video Doorbell 2.
Does anyone know of any custom code or any other way that I can get Alexa to run the Routine with the ZSE29? As I mentioned, the ZSE29 is paired with the SmartThings Hub, SmartThings is integrated with Alexa, and the ZSE29 does appear as a device within the Alexa app. Thanks.
