Hi all. Been using SmartThings for about a year, but this is my first post!
I have a room without overhead light, but one switched outlet for a lamp. I’d like the switch to turn on a different outlet in the room (which is now a Z-wave-enabled outlet). The main problem I’m encountering is that the wall switch is a 2-wire setup (interrupts the hot side of the outlet). I purchased a Aeotec G2 micro switch, and ultimately learned that it requires a neutral wire, which I don’t have in the gang box.
In theory, I could bridge the existing hot/cold wires inside the gang box, splice a piggytail to the hot side of the G2, and wire the neutral to the ground of the light switch [that’s a an electrical code violation, and I probably shouldn’t do it; mine is a home run circuit where the ground and neutral are connected on the same bus bar]. That way, the currently switched outlet would have constant power, and the Aeotec G2 would also have constant power. The G2 would just effectively become a remote control (not actually using its relay to control anything) using the existing in-wall switch.
Here are the questions:
Is this setup even possible, or does the G2 need a load of some kind? Given that the G2 operates at less than 6.66 mA (according to their documentation), would it be dangerous to wire it to the ground? Is there some better way to accomplish this, that doesn’t involve putting a second switch on the wall?
