Inclusion on behalf of the gateway Nodon Octan
Anyone with experience on this function?
Does it work? Is it helpful in real life when you include something that is not close to the hub under the inclusion time?
Regards
@einars I just try the script from :
  • Copyright 2015 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • ===== Nodon Octan =====
  • Modified for NodOn Octan Remote (CRC-3-1-0x) by Richard_Woodward
  • Octan supports 4 actions per button Pushed
  •    								Double Tap
  •    								Held
  •    								Hold Released
  • v1.01 Updated to support all 16 actions:
  • As Smartlighting can only support type “Pushed” or “Hold” events the extra 4 functions have been mapped to
  • fictional buttons 5 through 8.
  • Button 1 double Tap is mapped to “Button 5 Pushed” in smartlighting
  • Button 1 Hold Release is mapped to “Button 5 Hold” in smarlighting
  • Button 4 double Tap is mapped to “Button 8 Pushed” in Smartlighting
  • Button 4 Hold Rlease is mapped to “Button 8 Hold” in Smartlighting
metadata {
definition (name: “Nodon Octan”, namespace: “smartthings”, author: “SmartThings”) {
capability “Actuator”
capability “Button”
capability “Holdable Button”
capability “Configuration”
capability “Sensor”
capability “Battery”
  fingerprint deviceId: "0x0101", inClusters: "0x86,0x72,0x70,0x80,0x84,0x85"
simulator {
status “button 1 pushed”: “command: 2001, payload: 01”
status “button 1 held”: “command: 2001, payload: 15”
status “button 2 pushed”: “command: 2001, payload: 29”
status “button 2 held”: “command: 2001, payload: 3D”
status “button 3 pushed”: “command: 2001, payload: 51”
status “button 3 held”: “command: 2001, payload: 65”
status “button 4 pushed”: “command: 2001, payload: 79”
status “button 4 held”: “command: 2001, payload: 8D”
status “wakeup”: “command: 8407, payload: "
tiles {
standardTile(“button”, “device.button”, width: 2, height: 2) {
state “default”, label: “”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#ffffff”
state “button 1 pushed”, label: “pushed #1”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#79b821”
state “button 2 pushed”, label: “pushed #2”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#79b821”
state “button 3 pushed”, label: “pushed #3”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#79b821”
state “button 4 pushed”, label: “pushed #4”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#79b821”
state “button 1 held”, label: “held #1”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#ffa81e”
state “button 2 held”, label: “held #2”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#ffa81e”
state “button 3 held”, label: “held #3”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#ffa81e”
state “button 4 held”, label: “held #4”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#ffa81e”
valueTile(“battery”, “device.battery”, inactiveLabel: false, decoration: “flat”) {
state “battery”, label:’${currentValue}% battery’, unit:”"
main “button”
details([“button”, “battery”])
def results =
if (description.startsWith(“Err”)) {
results = createEvent(descriptionText:description, displayed:true)
} else {
def cmd = zwave.parse(description, [0x80: 1, 0x84: 1])
//log.debug(“cmd=$cmd”)
if(cmd) results += zwaveEvent(cmd)
if(!results) results = [ descriptionText: cmd, displayed: false ]
//log.debug(“Parsed ‘$description’ to $results”)
return results
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd) {
def results = [createEvent(descriptionText: “$device.displayName woke up”, isStateChange: false)]
def prevBattery = device.currentState(“battery”)
if (!prevBattery || (new Date().time - prevBattery.date.time)/60000 >= 60 * 53) {
results << response(zwave.batteryV1.batteryGet().format())
log.debug(" read battery")
results += configurationCmds().collect{ response(it) }
results << response(zwave.wakeUpV1.wakeUpNoMoreInformation().format())
return results
def buttonEvent(button, held) {
button = button as Integer
held = held as Integer
//log.debug(“button=$button Held=$held”)
if( held == 1) {
def ebutton = button +4
createEvent(name: “button”, value: “held”, data: [buttonNumber: ebutton], descriptionText: “$device.displayName button $ebutton was pushed”, isStateChange: true)
else if (held == 2) {
createEvent(name: “button”, value: “held”, data: [buttonNumber: button], descriptionText: “$device.displayName button $button was held”, isStateChange: true)
else if (held==3) {
createEvent(name: “button”, value: “pushed”, data: [buttonNumber: ebutton], descriptionText: “$device.displayName button $ebutton was pushed”, isStateChange: true)
else if (held == 0) {
createEvent(name: “button”, value: “pushed”, data: [buttonNumber: button], descriptionText: “$device.displayName button $button was pushed”, isStateChange: true)
def zwaveEvent(physicalgraph.zwave.commands.sceneactivationv1.SceneActivationSet cmd) {
Integer button = (cmd.sceneId / 10) as Integer
Integer held = cmd.sceneId - (button*10) as Integer
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: “battery”, unit: “%” ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = “${device.displayName} has a low battery”
} else {
map.value = cmd.batteryLevel
createEvent(map)
[ descriptionText: “$device.displayName: $cmd”, linkText:device.displayName, displayed: false ]
def configurationCmds() {
delayBetween([ zwave.configurationV1.configurationSet(parameterNumber: 250, scaledConfigurationValue: 1).format(),
// zwave.associationV1.associationSet(groupingIdentifier: 2, nodeId: zwaveHubNodeId).format(),
// zwave.associationV1.associationSet(groupingIdentifier: 3, nodeId: zwaveHubNodeId).format(),
// zwave.associationV1.associationSet(groupingIdentifier: 4, nodeId: zwaveHubNodeId).format(),
// zwave.associationV1.associationSet(groupingIdentifier: 5, nodeId: zwaveHubNodeId).format(),
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format(),
zwave.configurationV1.configurationSet(configurationValue: [3], parameterNumber: 8, size: 1).format(),
zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId).format() ],500)
def configure() {
def cmd = configurationCmds()
//log.debug(“Sending configuration: $cmd”)
return cmd
def installed() {
initialize()
def updated() {
initialize()
def initialize() {
sendEvent(name: “numberOfButtons”, value: 8)
log.debug(“Sent numberOfButtons 8”)
Orginal here but miss the last } and I rename the handlers Device Nodon Octan =>
Add it’s work for me !
Cool, tried it and it works great for 8 buttons function.
Thx for tips.
