Including MultiChannel device always uses DTH not Edge Driver
Hello,
Do you know if the HeatIt Z-push 8 will work with the Namron version of it??
They seem to be identical but Namron will not transfer over to edge. Stuck in groovy mode.
Will adding the fingerprint of the Namron version to your Heatit version fix this?
Hi Ivar, good job on Heatit Z-TRM2 & Z-TRM3 drivers. Have some feedback.
I have 2 Heatit Z-TRM3 and have noticed 2 things:
  1. I can not set a ā€œnegative valueā€ in settings for the ā€œā€¦ sensor calibrationā€ setting?
  2. When increasing/decreasing ā€œHeating temperatureā€ I can only do it in steps of 1 degree.
    It would be nice if you can do it in steps of 0,5 degree (or even 0,1) as on the device it self directly.
Many Thanks
These use default capabilities and settings from SmartThings.
  1. You can paste a negative value. I will ask for fix from SmartThings
    2 I have requested a possibility to adjust step (0.5 or even 0.1) in the capability.
Thanks for feedback :+1:. I will try to ā€œpasteā€ in Smartthings Web app, doeesn’t work on my Samsung Galaxy. Hope Samsung Smartthings can fix it :blush:.
Would be great if they also could fix ā€œstepsā€, seems to be an issue in other scenarios as well.
