Hello all, wanted to pick people’s brains about a particular scenario that thus far I have been overthinking
When my dad leaves the house (which would be to drive) I want to make sure he doesn’t forget his cell phone. seems easy enough….
the closest hardware solution is a MYNT tag on his car keys keychain that beeps when separated from the phone - however I find it relatively unreliable and depending on it being in a pocket in a running car not something one would hear anyway. I’m hardly the first person to complain that the otherwise lovely tile bluetooth tags do not seem to have this sort of capability.
even dipped my toe for the first time into the world of bluetooth beacons, with the very interesting beaconthings app
I’ve even gotten to the point where I am literally willing to put a old iPhone 4s + a hotspot from freedompop (not an endorsement but 500 free megs a month on sprint) - nice way to call the car with FaceTime voice in a pinch)
about as far as I got (untested) but perhaps using the also excellent smartrules maybe have a beacon leave (in a car) but presence sensor (phone) being present at home - send alert to the spare iPhone 4s in car that hopefully will play over bluetooth in the car…
anyway, a fresh set of thoughts on how to accomplish this without false positives (say every time leaving home or every time parking the car somewhere) or some hardware device that the ST community has bent to it’s will beyond it’s original purpose
@obycode for props for beaconthings and smartrules
thanks
You’re solution will work but it messy, and you already know that. I wouldn’t want an old phone to be connected to my bluetooth because then I would have to keep that phone updated with any media I want to listen to in the car.
@yvesracine might have an idea using Automatic’s bluetooth OBDII adapter. It is essentially a car monitor, but it has a speaker in it to beep at you and that might be controllable through ST talking to the API. You obviously get the added benefit of the car monitoring services.
Does your dad park his car in a garage? you could try putting a beacon, a motion sensor and a talking speaker in the garage. Then write a rule that if motion is detected in the garage while the beacon is not present, speak an alert “Don’t Forget Your Keys”.
Maybe flash the garage lights too, if you want to get fancy.
The integration with Automatic would be very cool if that is possible.
BeaconThings still has plenty of problems and should be considered a proof of concept more than a solid app at this point. I hope to make time to add to it at some point, but its not there yet.
Are you saying that Tile Mate or TrackR would not meet your needs? They have distance proximity and the TrackR says that the beep can me set to as loud as 92db. That is as loud as a train whistle or jackhammer.
tile mate does not have “reverse” functionality (when phone disconnects from tile) unfortunatly it is otherwise quite reliable, I never tested the TrackR but reviews were always subpar, I HAVE tried the MYNT, it’s gotten better, which isn’t saying much - unreliable at best and many false positives within the house (they added a capability where it doesn’t trigger when on home wifi but I also found this feature hit or miss)
