Ikettle with smartthings?
Is the kettle compatible with smartthings?
Also can I dim the hue lights with our a wall dimmer switch? Using echo?
No. There is one guy who managed to make it work with a really complex set up that requires both code and device additions and quite a bit of technical skill. So here’s his blog article, which you will likely either find fascinating or tedious. :wink:
https://medium.com/mark-rittman/the-story-behind-the-ikettle-the-eleven-hour-struggle-to-make-a-cup-of-tea-and-why-it-was-all-769144d12d7#.afv3mb8in
Absolutely! You don’t even need SmartThings for this, as the hue bridge has a native integration with echo. it can do on/off/dim.
It can’t change color directly, but in the US you can use echo to activate a scene you set up in the hue app, so as long as you predefined the colors that you want you could have voice control of those as well. I believe that’s working in the UK as well, but if someone can confirm that, that would be helpful. The on/off/dim definitely works in the U.K.
