I need some help with Aqara Single Wall Switch (With Neutral).
I have this switch associated with Smartthings HUB with custom device handler. I also have some IKEA TRADFRI On/Off Button. All of these works fine, but any IKEA Buttons controls the Aqara switch! If I press IKEA “I” button, the Aqara turns on, If I press the “O”, it’s turns off.
Somebody met this problem?
Can I send a raw command to switch to turn a whatever parameter to disable this?
What can I try?
That’s the facts:
If I remove the IKEA button from smartthings, it’s continue controls the Aqara switch
If I unplug the LAN cable from ST, button still controls the switch (so it’s runs locally)
If I unplug the power from ST, button stops controlling the switch anymore (so it’s controls via the HUB)
