You can see, that there are some teething issues with the remote. I am still investigating it. It looks like some behaves differently.
I can see only one issue with mine, that there is no held for the middle button. Only this in the log. And a left button press (meanwhile holding down the middle button). I’ve read some other people haven’t managed to make the middle button held working neither.
I’ve duplicated the important button automations with Smart Lighting…in the new app at least until they fix the cloud issue breaking custom automation rules for buttons.
I am not even seeing any of the button push actions. Just the battery status in the beginning when it is being paired and then it goes silent. Should maybe try returning the device?
Im glad im not the only one… This has been driving me nuts. I have 3 of the 5 button remotes for various room lights and they were working perfectly, then all of a sudden about a couple days ago they just stopped working. Looked a little bit last night in my app and saw that i can see the button presses just fine, but now there are no options for editing the pressed/held for each button. Wasnt sure if something was updated with Samsung on the backend thats caused this or if there is a bug in an update. Is this the same thing that you are seeing?
I have both old and new versions. Both stopped working now. and initially I had some issues with setting actions but pairing was fine. No problems with pairing. The issue I have now is that the app dumped all the button actions so they do nothing now, and you cannot edit them in the app. This other topic describes the same issues Im having now. Buttons stopped working after latest iOS update
Yeah, I see all the issues what people are saying about this buttons not working.
Have you tried to add the actions through Smart Lighting or webcore?
I guess all the issues what are reported are from the new app. I am not using the features over there because when I paired my remotes the app was crashing when you tried to assign any action.
I think, I dodged this bullet now.
@Brad_ST, is anyone looking at this issue with buttons and the new app not working together?
Not sure I understand what you mean by adding the actions through smart lighting? And Im not sure how to get add anything via the webcore as I cant add any actions via the web interface at least that I can find. I just got a response from support essentially saying that since the button is not an officially supported thing, im SOL. Not really sure how that happened considering that they literally were fine until a couple days ago… Might have to look into writing my own handler as much as I dont want to…
custom device handlers only change the UI in classic. The DTH tiles only map to classic. The new app uses plugins that can’t be manipulated by the DTH other than assigned a whole new one.
I can pair it but I only see the battery level in the app, no buttons (in both the new and classic app). When I look in the IDE, it shows as a 5-button remote but button presses don’t generate any events. I’m still on a V1 hub. I believe it’s the older version of the remote.
If you can’t see this, then you are using the wrong device handler. Select this one and re-pair your button.
I guess you installed a custom device handler, you might want to remove it to avoid confusions.
@BroderickCarlin, could you advise? Are the v1, ADT, Nvidia Shield versions supporting these devices? I haven’t seen any firmware update announcement for those. Or is the feature used is a cloud solution? Thanks!
