Ikea motion sensor
Same here, so its not phone relate…
My brother have same problem and mine works perfect, strange
I have reported it to the support mail address. Please do the same and reference my ticket number, 789876.
Same here.I have 2 tradfri Motion Sensor.Can connect with ST but no motion detected.
Cant understand but Sensor is found from ST as Ikea Tradfri Motion Sensor
Mine works pefect, can it be diffrent FW or batchers?
Support was clueless. They advised me to swap the DH to other motion sensor ones.
Actually paired it again and found this in the live log:
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:10:05 PM: debug Message description map: [raw:BE00010001082000201C, dni:BE00, endpoint:01, cluster:0001, size:8, attrId:0020, result:success, encoding:20, value:1c, isValidForDataType:true, clusterInt:1, attrInt:32]
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:10:05 PM: debug Parsing message from device: 'read attr - raw: BE00010001082000201C, dni: BE00, endpoint: 01, cluster: 0001, size: 8, attrId: 0020, result: success, encoding: 20, value: 1c'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:47 PM: error org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'true' with class 'java.lang.Boolean' to class 'java.lang.Integer' @line 143 (getGroupAddrFromBindingTable)
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:47 PM: info Found null
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:47 PM: info Parsing binding table - 'catchall: 0000 8033 00 00 0000 00 BE00 00 00 0000 00 00 4600010001AF8F7BFEFF57B414010100030100A0E9A4A852D001'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:47 PM: debug Parsing message from device: 'catchall: 0000 8033 00 00 0000 00 BE00 00 00 0000 00 00 4600010001AF8F7BFEFF57B414010100030100A0E9A4A852D001'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:47 PM: warn Binding Table Header:
[transactionSeqNo:70, status:0, numTableEntries:1, startIndex:0, numEntriesReturned:1]
Table Entries:
[srcAddr:14B457FFFE7B8FAF, srcEndpoint:0x01, clusterId:0x0001, dstAddrMode:3, dstAddr:D052A8A4E9A00001, dstEndpoint:0x01]
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:38 PM: error org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'true' with class 'java.lang.Boolean' to class 'java.lang.Integer' @line 143 (getGroupAddrFromBindingTable)
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:38 PM: info Found null
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:38 PM: info Parsing binding table - 'catchall: 0000 8033 00 00 0000 00 BE00 00 00 0000 00 00 4600010001AF8F7BFEFF57B414010100030100A0E9A4A852D001'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:38 PM: debug Parsing message from device: 'catchall: 0000 8033 00 00 0000 00 BE00 00 00 0000 00 00 4600010001AF8F7BFEFF57B414010100030100A0E9A4A852D001'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:38 PM: warn Binding Table Header:
Table Entries:
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:34 PM: debug Message description map: [raw:0104 0001 01 01 0000 00 BE00 00 00 0000 07 01 00, profileId:0104, clusterId:0001, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:BE00, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:1, commandInt:7]
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:34 PM: debug Parsing message from device: 'catchall: 0104 0001 01 01 0000 00 BE00 00 00 0000 07 01 00'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:33 PM: debug Message description map: [raw:0000 8021 00 00 0000 00 BE00 00 00 0000 00 00 4500, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0000, messageType:00, dni:BE00, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[45, 00], clusterInt:32801, commandInt:0]
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:33 PM: debug Parsing message from device: 'catchall: 0000 8021 00 00 0000 00 BE00 00 00 0000 00 00 4500'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:33 PM: debug Message description map: [raw:BE000100010A200000201C, dni:BE00, endpoint:01, cluster:0001, size:10, attrId:0020, result:success, encoding:20, value:1c, isValidForDataType:true, clusterInt:1, attrInt:32]
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:33 PM: debug Parsing message from device: 'read attr - raw: BE000100010A200000201C, dni: BE00, endpoint: 01, cluster: 0001, size: 10, attrId: 0020, result: success, encoding: 20, value: 1c'
[5c24eeb2-77b9-442f-bc82-0d1b3f717d51](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#5c24eeb2-77b9-442f-bc82-0d1b3f717d51) 10:09:27 PM: debug Configuring device TRADFRI motion sensor
There is some issue with the official DH for the newer models, must be.
Which DH are you using @kimmini?
Dont Think i using DH? I am not sure but i have to choose DH as type if i wanna use DH? I use Ikea motion sensor as type and its nativ i Think. I have 2 Ikea DH in DH list.
You use that dh from ikea treadfri light rgb for the motion sensor?
No i use Ikea motion sensor as type, so i dont Think i use any DH?
Thanks for this. Good to see if it’s the same.
I have a ticket open with ST support so let’s see what they say.
Hey,
Did you get anywhere with the motion sensor? I just bought 3 and all of them are connected to ST but none showing motion and one is showing 0% battery… puzzeling
Hello,
I’ve reported to support. They forwarded the issue inside one their departments. One of the zigbee engineers contacted me to confirm the device, as they were not aware of the new model, as it is not sold yet in the US, and suddenly IKEA calles the same way the devices. (Disregarding the 4 digit number.)
Let’s hope that they can untangle the issue and a working DH will be provided soon.
Anyhow the DH should be working without any issue with the old, 2 dial, 1 button versions.
Awesome,
I took them back today as impatience got the better of me, going to order some Aqara motion sensors.
Props to ikea for the rest of the line up, everything else seems to be working after some teething problems. I’ll revist once the DH gets sorted.
We are digging in to figure out the best way to resolve this for you guys. The primary issue here, as alluded to above, is that Ikea released a new model of their motion sensor in some regions and did not actually change the model name. This results in the new model matching to the DTH of the old model and the two are not functionally compatible. We believe that we know why the newer model is not reporting motion but need to confirm the fix. We don’t have an ETA yet but it is actively being worked on! :slight_smile:
The old motion sensor: https://www.ikea.com/us/en/catalog/products/50383505/
The new motion sensor: https://www.ikea.com/pl/pl/p/tradfri-bezprzewodowy-czujnik-ruchu-bialy-70429913/
That makes me happy. Please let us know if there is something new.
Would be great to get this working again, I have the same issue, just purchased a few sensors from Ikea, got them to pair with ST but no motion being detected. Please update us if it can work again. Many thanks…
@kimmini Can you please look at the links above to to see if you got the newer or older model? You said you got the newer model but just to make sure.
@kimmini, could you please confirm the firmware version on yours in the IDE?
Mine says 0x20022623.
Hi
I have 0x20022623 and its the New one whit 3 buttoms.
I have 2 sensors and both works but one is loosing connection somethimes but sensor is outside 60 meters away so i need to fix bettet mesh
© 2019 SmartThings, Inc. All Rights Reserved. Terms of Use | Privacy Policy
SmartThings; SmartApps®; Physical Graph; Hello, Home; and Hello, Smart Home are all trademarks of the SmartThings, Inc.
