I’m curious if there will ever be IFTTT integration as it pertains to mode changes?
You hack together some mode changes using virtual button tiles. Something like:
If X-happens, then IFTTT turns on virtual tile A. When virtual tile A turns on, SmartThings turns it off, then changes to mode Y.
I can’t recall if IFTTT can “accept” commands from tiles or not, but if it can then you could go the other way as well:
If mode Z is activated, then it turns on virtual tile B. When IFTTT sees virtual tile B turn on, it turns it off then executes function C.
